Car wont start, wtf is going on?
Old Aug 1, 2005 | 12:46 AM
eckohb's Avatar
I had the car running, pulled into mcdonalds, turned the car off. pretty normal, then get back in, try to start it up, starts to crank slowly and dies. After that, all i get is a click everytime i try to crank it up. What is going on here? Jumping the battery didnt work. Checked my fuses and they were good.
Old Aug 1, 2005 | 01:07 AM
maximazation's Avatar
maybe your starter is shorted...my friends civic had the almost same problem, the starter ground wire somehow wasnt screwed right on to the actual ground terminal, so it would sometimes start and sometimes die and not even start with a jump...
Old Aug 1, 2005 | 01:41 AM
eckohb's Avatar
why out of nowhere? never had any problems with it before tonight
Old Aug 1, 2005 | 02:44 AM
most likely its your starter...did you ever replace it?
Old Aug 1, 2005 | 02:52 AM
maxspeed96's Avatar
yup, same thing happened to me. thaught it was the battery at first. changed the starter and cranked right up.
Old Aug 1, 2005 | 04:41 AM
ChristheNite
it could just be an omen of things to come for you if you continue to eat McDonalds...creepy.
Old Aug 1, 2005 | 04:45 AM
robsst's Avatar
Almost the exact same thing happened to me with my 95 Max.
Wife went into the store, came back out. Suddenly, nada. Engine wouldn't even crank, just click.
Dealership replaced the starter.
Been good ever since.
Old Aug 1, 2005 | 05:12 AM
bkea's Avatar
I say battery. Get it tested at Advance Auto or similar. Similar thing happened to me years ago in my Hardbody truck, except I had stopped at Hardees for lunch. Had absolutley no forewarning or anything. It wouldn't turn at all and it couldn't be bump started. Was tough enough jumping it off.
Old Aug 1, 2005 | 05:23 AM
PAY_ME96's Avatar
Check the battery first!!! Same thing happened with my Max, battery was just too dead to jump. Replaced the battery, all gravy.....
Old Aug 1, 2005 | 05:24 AM
kbmaxima's Avatar
in my case, i got that clicking when trying to crank it. got a new battery and i've been running fine for 2 months now.
Old Aug 1, 2005 | 11:02 AM
DAVE Sz's Avatar
Hooooooonda.....
He got the battery tested and it's fine. I told him to try shorting the starter to see if it turns over, it doesn't.
Old Aug 1, 2005 | 11:35 AM
Ka$hThaRipper's Avatar
forget the starter
TRY BATTERY FIRST!....dont even bother jumping it..put a brand new one in, chances are that it WILL start..if not THEN start knocking the starter
Old Aug 1, 2005 | 11:41 AM
kormax97
it's not the battery. it's the starter. 110% sure.
Old Aug 1, 2005 | 11:48 AM
PAY_ME96's Avatar
Take it to autozone for a free battery and starter check.... DONE...
Old Aug 1, 2005 | 11:54 AM
NmexMAX's Avatar
dot dot dot ...
: your starter a few times ...
But since you stated it cranked slowly then dies, sounds battery related. How about interior lights, are tehy working .. etc?
Check and clean all ground points.
Old Aug 1, 2005 | 11:55 AM
MDeezy's Avatar
If your a 5-speed, doesnt matter how dead the battery is, you can pop the clutch and start it up.
NmexMAX's Avatar
dot dot dot ...
He's automatic ..... IIRC
Old Aug 1, 2005 | 02:45 PM
MaximaPower's Avatar
same thing happened to me...first i thought it was the battery and had that replaced but then the car died again, and all i get is a little click, click sound
it's the starter...$150 plus core exchange at autozone.....make sure u count the teeth on the starter, mine's had 10...napa had a starter but it had 11 teeth....not sure if that makes a different but i went with the 10
Old Aug 1, 2005 | 03:36 PM
Loe max's Avatar
If you get a single click, its your starter. If you get multiple clicks along with flashing dash board warning lights, its your charging system.
Old Aug 1, 2005 | 09:04 PM
eckohb's Avatar
I get a single click. it's the starter, my battery checked out at AZ. towed it with my dads 4runner to my house, and there it will sit til i feel like replacing the starter. im just fed up with my car lately, and this isnt helping its case
Old Aug 2, 2005 | 03:07 AM
gaab's Avatar
I had same problem, went to shocks and said either the battery or the ground wires is not ok. went to other shop and found out the battery died lasted me since 1997 till 2004. I went to car audio shop and picked Optima battery for about $180, becuse i want to run car system in my max. vooommm.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
Maxboy23
Aug 11, 2015 11:59 AM
