Diffrence in abs axle and non abs axle
Old Aug 3, 2005 | 01:03 AM
Maxima_Joe's Avatar
4th Gen Parts King
I'm wondering what the diffrences are in an abs axle and non abs axle?
Is it just the abs has a ring? I am going to be replcing my axles because the boots have been split for well over a year and i have to replace my trans anyway.
My car currently has abs and i plan on removing it since it will be a toy for the drag strip rather than a daily driver.I'm not sure there is much weight diffrence in the two axles so maybe i should get abs axles incase i want to put the abs back on. Anyone know what the weight diffrence is? Or yet how much all the abs components weigh? I was thinking around 50 pounds
Old Aug 3, 2005 | 04:22 AM
njmaxseltd's Avatar
The only differance in the axle is the toothed ring. It can't weigh more then a few ounces.
To remove the ABS system you'll need to take out the actuator and replumb the brake lines. You might need a different master cylinder as well. The sensors in the hubs are only a few ounces as well, just leave them alone. The actuator can't weigh more then 10 pounds, personally I'd just leave the system in there. The whole system can't be more then 10-15 pounds and you never know when you'll need it to stop you safely, even at the track.
Old Aug 3, 2005 | 06:59 PM
Maxima_Joe's Avatar
4th Gen Parts King
Thanks for the info. I have another max that doesn't have abs i was thinking of putting the abs on so i would have everything to swap back and forth. Is their more to the abs system other than the actuator, computer,and sensors? I won't probably do it if it's that light.
Old Aug 3, 2005 | 07:19 PM
RA030726's Avatar
I'm nutty for Nissans
the abs "ecu" is in the drivers kick panel. i say leave it be, its just a pain to swap all of that stuff out. better off getting a lighter battery or ditching the spare.
Old Aug 3, 2005 | 08:01 PM
Maxima_Joe's Avatar
4th Gen Parts King
I don't have a spare and my battery weighs 8 pounds. The last time i weighed my car it was 2650. I will probaly get abs axles since it won't matter either way if i don't want the abs and the cost is the same.
bbsitum
Sep 6, 2019 07:31 PM
RealityCheck
Oct 2, 2015 06:34 PM
The Wizard
24
Oct 1, 2015 08:47 PM
leatherneck
Sep 30, 2015 09:16 PM
maximusrising
Sep 2, 2015 09:55 AM
