Help with cluch problem!
Old Aug 3, 2005 | 12:52 PM
Powerman5115's Avatar
Hey. This morning I drove my car to band and it was hard to get the transmision into gears. It never occured to me that my clutch fluid could be low, I know I'm a dummy. When I got home I decided to clean my IACV, and I thought to check the clutch fluid and it was bone dry. I filled it up and just tried to go somewhere and could not get it into any gears unless I forced it, and it ground alittle bit when I tried to get it into reverse. I checked fluid level again, thinking there was a leak and the level was fine. The clutch is also real spongy until it catches. There is a lot more play before it catches than there use to be.
With the resivior being so low, my guess would be that I need to bleed the clutch lines.?. Or would I need a new clutch?
I'm about to go and look at it more.
Please help,
Mooney
Old Aug 3, 2005 | 12:54 PM
njmodi's Avatar
Do I get a tax break?
The fact that the fluid was low indicates that there is a leak. Fix the leak, bleed the lines and you'll be back in business.
Old Aug 3, 2005 | 12:58 PM
MDeezy's Avatar
Bleed it, check level again in a few days. If it bone dry and you fill it up, you have to bleed it. Inspect all lines for a leak.
Old Aug 3, 2005 | 03:04 PM
I inspected all of the lines and there is no leak. The only place I can see a leak is at the back-up light and nuetral position switch. It looks like break fluid, it's not red so I know it isn't transmission fluid. Does this sound right before I replace the switch.
Mooney
Old Aug 3, 2005 | 03:47 PM
xsnowpig's Avatar
the fluid that leaks from the neutral/back-up switch is gear oil. red fluid is auto tranny juice not manual gear oil. that particular leak is usually from the differential bearings starting to go. i don't think that's what is causing your clutch fluid leak.
Old Aug 3, 2005 | 04:20 PM
MDeezy's Avatar
Actually fluid leaking from that area could just mean that the switch may not be bolted down as tight as it should be. A Differential bearing leak, usually leaks thru the input shaft.
Old Aug 3, 2005 | 06:17 PM
xsnowpig's Avatar
Yeah that's what i meant. the first time i saw a leak near my neutral switch i replaced it and cleaned it all up. a short while later the leak reappeared and upon further inspection, i saw that the leak was actually coming from the imput shaft.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
