What do else do i need to add to my list to make my car run as good as it did factory
Old Aug 3, 2005 | 01:10 PM
2 Da Max's Avatar
ok before i start doing major mods to my car i want it to get to run as close to stock as possible, meaning i would like the hp to be the same or at least close to as how it was from when it was young
right now i have 80k miles on the car and its a 1996 auto gle
so far im making this list, help me add more items too it
clean, or new fuel injectors
coilpacks
take off tb and clean behind the butterfly plate
clean egr, even though i dont have to
radiator flush
change pcv valve
i already changed o2 and knock sensor,
maybe i should get an engine flush at the oil change place?
i was thinking about cleaning inside of the intake manifold, but the only way i could think of that is seafoam, which i have mixed feelings about
hhm i know thers alot more but i forgot the rest..
Old Aug 3, 2005 | 01:13 PM
njmodi's Avatar
Do I get a tax break?
Is this a parody thread?
If not then
Old Aug 3, 2005 | 01:16 PM
2 Da Max's Avatar
im going to be boosted soon, why would i do work to a car that has problems on it?? feel me? i want to make the car feel as fresh as possible and try to squeeze as much hp i can out of the motor before i boost
Old Aug 3, 2005 | 01:19 PM
njmodi's Avatar
Got it..in addition to your list...
1. air filter
2. fuel filter
3. tranny drain/fill or flush
4. PS drain/refill (with turkey baster)
5. new belts (PS and alternator)
6. clean IACV
7. new wiper blades
8. chevron techron in the fuel tank
extra cheap insurance:
1. replace ECTS
2. replace thermostat
3. replace radiator cap
Old Aug 3, 2005 | 01:25 PM
2 Da Max's Avatar
well air filter, fuel filter i did, and so did the tranny flush. thanks njmodi
just keep adding. i want the car to feel young again.. or like a virgin again
Old Aug 3, 2005 | 02:09 PM
chillin014's Avatar
You don't want to convert to 5 speed before you boost?
Old Aug 3, 2005 | 02:26 PM
laylow1988's Avatar
i would say check for vacuum leaks ,check belts,and hoses. making sure they are all up to par.
Old Aug 3, 2005 | 02:30 PM
Dubbya's Avatar
VK56 Inside
Or at least get a VB Upgrade and a cooler. Your stock transmission will be toast.
Old Aug 3, 2005 | 02:36 PM
MDeezy's Avatar
Compression check can help you to see the health of your current engine. Pull the plugs and inspect the tips, they can tell you alot.
Maybe drop the oil pan and clean it out properly.
Are you going to use teh Turbo you had for sale?
Old Aug 3, 2005 | 03:33 PM
MystA RavE's Avatar
Do you know how to clean the EGR and TB yourself? If you do, would you be willing to do this for me if I came down to queens and paid you? I'm not good with any of this stuff...
Old Aug 3, 2005 | 04:19 PM
AxisKill's Avatar
good thread.. this is pretty much what my agenda has been (get car back to stock before bigger mods)
i would reccomend spark plugs (go with the ngk-copper 1 step colder, they last 10k ..)
don't know what you meant by engine flush, but check your tranny fluid, (im also auto with 115k miles though) and mine is pretty black :-/
aside from that check your brakes, lines, rotors, calipers... it turned out my rotors were warped (at a bad time) had to replace all of the above for quite a price (it hit hard when i wasn't expecting it).
next big performance items would be the knock sensor and o2 sensor but you're on top of that..
that's all that comes to mind atm..
Old Aug 3, 2005 | 04:23 PM
MDeezy's Avatar
2 da Max I would like to advise making sure that for certan sensors and such you test them with a multimeter to make sure they are fully fuctional. If they are then there is no need to replace then, as the new item will perform just like the old one, you can save a lot of money by doing this, and let the saved money go towards tuning, or guages,or pipes etc.
Old Aug 3, 2005 | 04:58 PM
2 Da Max's Avatar
well i just installed brembo crossed drilled rotors and ebc greenstuff pads, about 2 weeks ago. i did a full tranny flush 2 weeks ago as well, including changing the tranny filter.
i put ngk platinums in there 10k miles ago as well.
Mdeezy, it is not the same turbo for sale, i might get a SC, and im really thinking of the 5sp, because my tranny is kind of sluggish right now
Old Aug 3, 2005 | 05:03 PM
Chickan's Avatar
5 speed is my hero, though I'd say sell your max and get a 5 speed one .....
Also you might pull off the intake manifold and change the spark plug tube seals, valve cover gaskets, etc. etc.
And you could think about pulling your main drive pulley off and replacing that little ***** of a seal behind it (that has started leaking on my car ) Axles?
Old Aug 3, 2005 | 06:02 PM
MaximaSpd85's Avatar
sorry for the noob question but, in brief wut exactly does the iacv control/do?
Old Aug 3, 2005 | 06:18 PM
Bobo's Avatar
Rather than an engine flush, consider an AutoRX treatment. It takes 1,500 miles on the clean phase and 2,000 miles on the rinse phase. I am 600 miles into my clean phase and will be switching to synthetic after the rinse phase. See www.auto-rx.com
This should rid the engine of any varnish and sludge buildup and helps restore the seals.
Old Aug 3, 2005 | 06:19 PM
Bobo's Avatar
IACV = idle air control valve - controls the engine idle.
Old Aug 3, 2005 | 06:33 PM
oh ok, can messing with the iacv help acceleration or performance somehow or is that not wut the purpose is?
Old Aug 3, 2005 | 06:41 PM
2 Da Max's Avatar
it just helps control your idle, so its not jumpy
Old Aug 3, 2005 | 09:39 PM
Bobo's Avatar
Cleaning the throttle body will help with throttle response and acceleration.
Old Aug 3, 2005 | 09:40 PM
i've cleaned it, but i didnt take the tb off. is it hard to take off? i figure i can clean it better if i can get my darn hand in there easier
Old Aug 3, 2005 | 10:59 PM
maximus_96's Avatar
i thought the coppers last 30k miles? am i wrong, if so then i'm about 15k miles overdue for new plugs...
Old Aug 4, 2005 | 07:01 AM
MDeezy's Avatar
coppers are 30K
Old Aug 4, 2005 | 07:13 AM
sdoherty_tjm's Avatar
if you plan on getting boosted 2 da max, i would buy the book Maximum Boost. its the best turbo book there is, and you can use it to make your own kit.
Old Aug 4, 2005 | 09:12 AM
Majestic's Avatar
Yahhhhhhh
Question
From what I was told when i had my Camry. Do you run the risk of an oil leak when running full synthetic since it cleans the buildup out? This is the only reason Im afraid to do this in my Max. I did it with my Camry and I got leaks. Synthetic is too expensive to be replacing because of leaks.
Old Aug 4, 2005 | 09:18 AM
Bobo's Avatar
Originally Posted by Themajesticking
Question
You only run the risk of an oil leak if you have a seal problem.
Like I said above, buy a bottle of AutoRX. It will help restore the seals and clean varnish and sludge out of the engine. The synthetic oil will also clean any slugdge buildup but your seals will be in better shape first. See www.auto-rx.com
Old Aug 4, 2005 | 09:40 AM
Majestic's Avatar
Yahhhhhhh
I guess my question is: Is it common for seals to go in the VQ?
Old Aug 4, 2005 | 10:54 AM
urmab's Avatar
if you goin to boost ur car i recoment goin 5 speed first althou its not needed but it makes it alot funner
Old Aug 4, 2005 | 11:10 AM
Bobo's Avatar
Old Aug 5, 2005 | 01:08 PM
shasmax's Avatar
just bought my 95 max for $6500, has 115k on it. what should i do first for maintence
Old Aug 5, 2005 | 01:10 PM
njmodi's Avatar
The first thing you should do for the maintainance of your maxima.org account is to stop posting the wrong thing in the wrong threads.
The next thing you should do is read the stickies.
Old Aug 5, 2005 | 01:44 PM
G4nismo's Avatar
ah ha ha ha... i agree, now get 2 it!
Old Aug 7, 2005 | 09:10 AM
2 Da Max's Avatar
clean iacv? i never did it maybe becasue im lazy.. ill probably do it today then
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
