Lost low end power
Old Aug 3, 2005 | 02:27 PM
hollaatchaboi's Avatar
Lost low end power
I have a ram air inake, warpspeed y pipe, and an axle back muffler. I changed the knock sensor about a month ago. But my take off and low end power isn't wat it used to be. What can it be or what can i do to get it back? For instance, the car can't even peel out like it used to.
Old Aug 3, 2005 | 02:31 PM
Loe max's Avatar
Replace your short ram with the stock and see if you 'feel' any difference. Everyone elses butt dyno lately has said so.
Old Aug 3, 2005 | 02:32 PM
MDeezy's Avatar
Gotta love the stock air box.
Old Aug 3, 2005 | 02:34 PM
NmexMAX's Avatar
dot dot dot ...
Stock air box > j00
Old Aug 3, 2005 | 02:35 PM
maxgtr2000's Avatar
KH3 by popular demand
Seafoam and throttle body cleaning is your friend. Also, when's the last time you changed your plugs and fuel filter?
Old Aug 3, 2005 | 02:37 PM
NmexMAX's Avatar
dot dot dot ...
I still think the stock air box will do the trick.
Old Aug 3, 2005 | 02:53 PM
wat if i use the stock box.....but leave the aftermarket mid pipe?
Old Aug 3, 2005 | 02:56 PM
sterlingmaxima's Avatar
the mid pipe is really what kils the power but i love the sound screw the 2 horses or what ever
Old Aug 3, 2005 | 02:59 PM
what about if i get an extension and make it a cold air?
Old Aug 3, 2005 | 03:04 PM
99Automagic
Nooooooooo. It's the mid pipe that kills your low end, IF that is what's causing it. The stock mid pipe will bring the low end back. You can use whatever filter you want. That won't make a diff. My Apexi filter on the stock mid pipe works great. Don't take off the snorkel or the bottom part of the box. The bottom will hold your after market filter in place. The snorkel will give you a extra source of cold air (I think).
Old Aug 3, 2005 | 03:14 PM
Ok..therefore i can put the stock mid pipe back on (if i can find it) and leave the cone filter on?
Old Aug 3, 2005 | 03:16 PM
99Automagic
Yesum. Stick the stock mid pipe onto the TB, next will be the MAF sensor, then attach the cone filter to the MAF. Hopefully your intake came with a MAF adapter.
Old Aug 3, 2005 | 03:30 PM
it did....i've had it on for a while. I just recently changed the cone. But latey the takeoff has been sluggish. I do know i need new spark plugs also. I think ill look into the seafoam etc
Old Aug 3, 2005 | 06:21 PM
MaximaSpd85's Avatar
dont worry man, my cars still slower than anyone's here! seafoam it, even if it doesnt do anything the smoke makes u feel like it is :-)
Old Aug 3, 2005 | 06:42 PM
99Automagic
If I recall correctly, my low end loss with a after market intake was gradual as well. It didn't happen over night, but it steadily got worse over time.
Old Aug 3, 2005 | 06:43 PM
2 Da Max's Avatar
lol werd, the car sounds like a beast!
Old Aug 3, 2005 | 06:53 PM
quasidynamic's Avatar
is there a writeup on seafoaming for our cars? i was always afraid of doing it wrong...
Devin
Old Aug 3, 2005 | 07:09 PM
i know theres a writeup, cant find it...but its simple....i think u gotta use 1/3 of the can through the brake booster line, the car will try to turn off, just rev it a little, suk up the 1/3 slowly, not quik, something about flooding something... once u suk it all up connect the line and shut the car off for bout 10-15 minutes. turn on and car should smoke like crazy, all the carbon burnin off i think!
Old Aug 3, 2005 | 07:24 PM
99Automagic
Devin
http://forums.maxima.org/showthread.php?t=308576
There you go my woodland friends. Alot of info on seafoam in this thread.
Old Aug 3, 2005 | 08:39 PM
G4nismo's Avatar
what are sum common problems due to seafoam? do they rarely occur?
o2 sensors failing due to the smoke?
i wanna do this but i heard from 1 orger sayin his car was stumbling and got som CEL codes
Old Aug 3, 2005 | 08:45 PM
yeh, ive heard that some peoples o2 sensors went. some say to just clean them and then reset, or if they go b/c of seafoam that they were gonna go soon anyways. its ur call, i didnt have any problems....dont know wut it did, but the smoke sure was cool lol
The Frye
Sep 2, 2021 11:03 AM
lowpost99
Sep 8, 2015 05:06 AM
TheMafia
Sep 4, 2015 08:26 AM
trungg86
Sep 4, 2015 04:58 AM
