Muffler tips
Muffler tips
Does anybody have a recommendation for where to get good muffler tips? Which size/length do I need to get? BTW...I dont want ppl sayin "DONT GET IT GET A MUFFLER" because thats not what I asked...
A tip is not a tip. The tip on my car changes the sound dramatically. Personally I like how my car sounds without it, but it looks like ***. I need to find on that is fairly long and doesn't change the sound. Just go to an automotive store, buy one, try it out for sound and fit, and if it doesn't work for you return it and get another one.
I thought they were purely cosmetic!
What type of tips would you recommend for a good deep sound for my Borla?
Originally Posted by MystA RavE
I want it to full in a lot of the missing space in the back circle...will that be around 3.5"?
Originally Posted by chenzarino
my muff has a 4" tip and it fills the gap nicely. Only abouta half inch between the bumper and the tip.
My HKS has a 4" tip as well and it looks perfect. If I were to stick a tip on a stock muffler, I'd chop off the existing stock tip and weld on the new tip. Otherwise I think it's ugly because you'll be able to see two different tips, the smaller stock diameter one and the larger new one.
btw, any ol muffler shop should carry a bunch of tips.
Originally Posted by Northern Maxima
I just ordered a Borla Pro XS Large Oval tip and it fills up the hole. I haven't received it yet, but bhmax16 has pics of it on his Car Domain. It is 2.5" and its stainless steel. The only problem is that it costs $59. It better not fall off! I'm going to have to secure it really well! It looks really hot though.
Post Borla pics please...
http://www.cardomain.com/ride/837045
Originally Posted by bhmax16
Yes that tip does fill up the bumper cutout nicely. Too bad it's off center now since one of the exhaust hangers by my cat completely rotted off so now the whole thing is crooked! And just so you know the tip I have isn't a direct fit..you'll have to weld a piece of pipe between the muffler and the tip to make it fit. Upside is once you do that you won't have to worry about it falling off
Uh oh...I hope my mechanic can weld that on then! Cause I sure as hell can't!
The Borla has the ability to be clamped on with a built-in clamping mechanism that it has but even though the Borla site says it will fit a muffler with a 2.5" outlet I found this not to be the case. Since it clamps on the outlet must be less than 2.5" so the tip can slide over the outlet. That's why I had to have my mechanic weld a small piece of pipe between the muffler and the tip. I believe all tips should be welded no matter how they're made to connect to the muffler. It just provides a much stronger connection
Is the Borla a screw on tip or it has to be welded? Can I just screw it on or itll look bad because the stock exhaust can still be seen?
i polish my tip.. the factory one.. hehee.. and man does that badboy shine.. i mean really shines.. its sexy.. even though my muffler is corrodign.. heh.. damm ny winters... need a new muffler soon...
I just bought a 3" tip from Advance Auto and I love it...it was a screw on type but I got my factory tip cut off and the new one welded on so I have no fitment or lose issues regarding it. I think the 3" tip looks really nice....the 4" gives it a more sporty look whereas the 3" stays with the classy look of the Maxima while giving it some edge. Also it only cost me $20.00 and it is stainless steel.
sdotcarter
Sep 2, 2015 09:53 PM
Justin Kroll
Sep 2, 2015 11:06 AM
. I made sure this last one I put on there was on really tight.
gotta watch out for that.
