Weird Idle Issue after manual swap...
Hey, I've been having this weird Idle issue for a couple of days, when i'm in gear and driving, and i press the clutch pedal all the way down, the rpm's should go down to idle speed. Instead, they hang around 1500 rpms or so for about 3 seconds, then drop down to normal speed. I have cleaned out my throttle body with seafoam, but haven't cleaned the IACV yet. This problem is getting more and more annoying, and at high rpms, it makes it feel like my clutch is slipping. I know it's not, it's an almost brand new clutch. Could the problem be the IACV?
I'm also using an auto ECU, could it be a product of that?
I know someone had this problem before, but I couldn't find the thread after searching on google.
Thanks in advance.
-Freddy
Thanks in advance.
-Freddy
They're supposed to hang up ~ 1500RPM for a few seconds, this provides better RPM matching while shifting through the gears (I believe,) a little less wear on the clutch.
If you're shifting at 3k, and the next gear starts up at about ~2k or so, 1500 is much closer to match then idle...
hmm...it didn't do that for the first 500 miles..yesterday it just shot up to about 2200 rpms, and stayed there, until about 5 seconds later. I know that's definitely not normal. And since i'm still using Auto ECU, why would it do this?
well, could be a vacuum leak when I didn't tighten down the airbox assembly. I tightened everything down, cleaned the TB...and hoped for the best. It hasnt happened again today, but I'm just concerned about the rpm's hanging...if it's normal, i'll deal with it I guess. I'll try putting in the 5spd ECU, and seeing what happens.
I know that I've left my foot on the gas pedal sometimes while I'm shifting and that has caused it to hang higher in the rpms. 'course I've got some pretty big feet too. maybe that's part of the reason. Some of the pedals are pretty sensetive to even the faintest touch or pressure.
I am still using a the auto ecu as well. Its the transmission itself that causes this. It is not computer related. Putting in the manual ecu will change nothing.
This actually a feature to help with driving the manual like tomservo said... It is your friend.
Originally Posted by i30ds
You probably just didnt notice it. I noticed it with in a few miles once I swapped.
What does it mean if my car DOESN'T do that??? The 1400 rpm "hang"? I've always seen an idle problem, where the engine speed will drop below idle when putting the car in nuetral and coasting. Instead, could this be tranny related somehow? There have been about 5 transmissions in my car since I've had the car (PLEASE NOTE: the reason there have been so many in and out was because all of the replacements for the original were faulty somehow, and continued to leak fluid.), so maybe something isn't connected right? I haven't performed a vacuum test, but was going to get around to it soon, nor a compression test (wasn't even planning on that one actually). Does any of this make sense?
if I have the clutch disengaged, how would it be a product of the transmission?
Youre right... Then it must be flywheel related... something mechanical, not ecu related though.
which leads me to think it might be a vacuum leak or diry IACV. If the problem persists, i'll clean out the IACV and see what happens.
MAXSE5SPD
Sep 17, 2022 04:00 AM
pktaske
May 6, 2016 07:49 AM
ballerchris510
Sep 10, 2015 09:35 PM
pktaske
Sep 4, 2015 08:40 AM
