my keyless is broken somehow. Daniel Martin?
Old May 23, 2001 | 02:36 PM
Justin95SE's Avatar
anybody have any ideas as to what the culprit could be? It is weird, the alarm still works, however, none of the keyless features work. And no its not the battery in the remote, i have tried everything i can think of. My only question would be are there fuses that could keep the keyless from working. For example, i replaced the interior illumination fuse and now my horn works. just wondering if that could have anything to do with anything. any help would be appreciated.
Old May 23, 2001 | 02:47 PM
hattyhat's Avatar
My brother had this problem on his 95 GLE, he ended up having to take it to the dealer, it was something with the chip inside. They charged him $80 so he wasn't too happy.
Old May 23, 2001 | 02:54 PM
DCmax's Avatar
Justin:
Did any of the keyless' symtoms include a loss in range as far as locking and unlocking doors? I used to have incredible range but now it isnt too good.
Old May 23, 2001 | 03:07 PM
Justin95SE's Avatar
i dont recall that being a symptom...
it was weird. one day everything worked fine. next day no keyless stuff worked. umm, i know its not the remotes i have because neither work now and i have replaced both batteries. On a funny note though, one day i was just messing with the remote and cursing it saying work darn you work. Eventually my pressing of the unlock button became a full body motion including me jumping up and down in frustration. Well this jumping eventually caused me to lose my grip on the remote and somehow throw the remote in the only puddle within hundreds of yards. Dont know what that has to do with anything, just thought it was kinda funny.
Old May 23, 2001 | 03:40 PM
hattyhat's Avatar
Re: i dont recall that being a symptom...
Then I think it is definately a problem with the chip inside. I think the only way to fix this is from the dealer reprogramming you a new remote to your car. Its a pain but I think the only possible solution.
Old May 23, 2001 | 03:42 PM
hattyhat's Avatar
Originally posted by DCmax
Justin:
Where or how did you do your tail lights? Looks good.
Old May 23, 2001 | 05:27 PM
jay_x's Avatar
Justin:
It may sound stupid, but if you hold the transmitter to your chin (and press the button on it), you get more range. Your body becomes an antenna (kinda like messing with the TV antenna).
Old May 23, 2001 | 05:58 PM
vmok's Avatar
be sure to check eBay... sometimes the transmitters go for like $10-$20 bucks there. there's instructions all over the web and at several of the member here's web sites that tell you how to program transmiterrs for your car. I dont' know why both would go out at the same time though.
do the doors lock and unlock fine with teh switch at the driver's door? when you put the key into the driver's door, does one turn unlock the driver's door and a second turn unlock the rest of the doors? what you say the alarm still works, do you mean that the lights still blink twice when you press the lock button?
is there anything else around where you're parked now that can be generating electrical interference? that might cause problems as well.
-V
Old May 23, 2001 | 06:08 PM
DCmax's Avatar
David L
http://home.earthlink.net/~davidl7/index.htm
Old May 23, 2001 | 06:17 PM
Justin95SE's Avatar
V-mok... thanks for the interest
ok here is every last detail that i can think of regarding all of the keyless/alarm stuff.
1.) When i lock and shut the door, all doors lock and the alarm becomes armed... the LED stays on for oh 20 sec and then begins blinking.
2.) When i turn once, the drivers side unlocks but 2 turns unlocks all doors.
3.) The remotes are worthless. No matter what i do, even reprogramming other people's to work with my car, nothing happens. So there is no blinking when lock buttons are hit.
4.) I dont think there is any interference, they dont work regardless of where i am.
Old May 23, 2001 | 08:59 PM
Daniel B. Martin's Avatar
You could try reprogramming your Keyless Remotes.
Go to Steve Cutchen's excellent MaxFAQ page:
http://web2.airmail.net/scutchen/max_faq/
Click on SUBTOPICS below Maintenance.
Click on Programming the Keyless Remote
Old May 23, 2001 | 09:50 PM
Justin95SE's Avatar
thanks all
thank you for the suggestions.
Old May 23, 2001 | 10:47 PM
Maxima81's Avatar
Accidental reprogramming?
Funny this post came up today. Cause the same thing happened to me just two days ago. I used my keyless to unlock the doors just fine, drove it to my friend's place, parked and proceeded to press the Lock button. After walking away for about 10 feet and pressing a few times, I noticed the blinkers didn't go off like they usually did. So returned to the car and did that whole reprogramming process. (Had to reprogram once more when I got a hold of my spare remote today..)
No idea why it would seemingly reprogram itself. But a simple reprogram fixed my problem. Although you already said you have tried other remotes... so it seems that doesn't work.... My guess is some fuse blew out??
And has anyone else ever had this "accidental reprogram" take place or know why?
Old May 24, 2001 | 12:32 AM
vmok's Avatar
Re: V-mok... thanks for the interest
ok... (2) was to check the logic of the system. I don't know if Dan can help us here, but there may be some sort of antenna lead for the factory alarm/keyless entry. I don't know, but if that is the case, it could be this became disconnected. When I was working on my brother's 300ZX, we noticed that the door locks and the pin switch wiring all went into the ECU and were controlled through the ECU. However, if the unlock logic works (1 turn 2 turn thing) it'd seem like everything is hooked up/working properly.
When you say you're reprogramming other people's transmitters to work on your car, is your car responding the way it should be (i.e. after unlocking the door x number of time, the parking lights blink, then blink again when you program the first transmitter, you unlock/lock and try again?)
-V
Old May 24, 2001 | 07:14 PM
Justin95SE's Avatar
yah all that stuff worked
as far as i know, all things worked fine and provided there was nothing wrong in the ecu, the remotes should have worked
litch
123
Jan 4, 2024 07:01 PM
James92SE
142
Jan 2, 2024 09:23 AM
tarun900
19
Dec 20, 2021 06:57 PM
flu2000
Sep 14, 2015 12:34 PM
Hailstatejig
Sep 2, 2015 06:52 AM
