Uphill battle from 2-5 gear
at a reasonable speed say 35- 45 miles per hour going uphill in second third fourth or fifth gear my 1995 5spd seems to sputter like maybe theres a vacuum leaqk... my dad and i checked for vacuum leaks but couldnt find one. i recently replaced the TPS and the KS. I have a brand new Short Ram intake on the car with NO LEAKS. However i am getting a reading for MAF and Intake Air Temp Sensor from the check engine light. Will this Cause my problem? OH btw, i put new NGK sparks in and new fuel filter. I used the old listen to the screw driver trick on the injectors and they seems to work well..
any Suggestions????
Oh and another thing on take off, the car runs great [1st gear] until at about 3500 rpm, it seems like it is straining to run faster.
thanks in advance
any Suggestions????
thanks in advance
From what I've read this issue could be caused by a bad MAF. Did you have a CEL for MAF and Intake Air Temp Sensor prior putting on the aftermarket intake?
That's where they're both connected to.
ok just went out and bought new mass air flow sensor...........CEL is gone now but car isnt having the same problem as bad.....should i put my orginal air intake back on and see if its still doing it or is there any other suggestions?
im not getting any codes now!!!!!!there is no check engine light....just the car is still doing the same crap- like it hesitates then catches once u take off in second gear or is going uphill
knight_yyz
Nov 1, 2015 01:34 PM
