vibration past 100 mph
Old Aug 9, 2005 | 08:49 AM
kasemodz's Avatar
I was crusing along the highway since i saw another maxima going really fast. Of coursei have 97 stock and the other guy had a 2003 maxima with stick shift. So he killed me. But anyways once I passed 100 mph, my car started to really vibrate a lot. I have gone 120 on my max without any problems. I did increase my idle air control valve to about 950 rpm.
one more thing. When I tried to floor my maxima, for some reason my the rpm didnt wanna go over 4000 rpm. It eventually did but took a while.
Old Aug 9, 2005 | 08:52 AM
sdoherty_tjm's Avatar
there was a post similar to this a day or two ago, was called "is this supposed to happen" or something like that. that was when he was going like 120, so you might have the same thing, didnt read it all though
Old Aug 9, 2005 | 09:02 AM
MaxxAddict's Avatar
well, my maxima vibrates when I go over 90 mph or so.... It does have plenty of acceleration left, but by no means is it as stable as a beamer/porsche at those speeds.
Old Aug 9, 2005 | 09:06 AM
Bobo's Avatar
Are you talking engine vibration or do the wheels need to be balanced? Are you saying you set your idle at 950 rpm? If so, reset it to 600 to 700 rpm where it should be.
Old Aug 9, 2005 | 09:10 AM
ImmaSquashYou's Avatar
its mostl ikely the tires.....also could be tire pressure. also it helps when you tell them what tire pressure you want before they balance it...
Old Aug 9, 2005 | 09:34 AM
99Automagic
strange....
my car vibrates at 80mph, but is stable as all hell when it's anything past that mark. But my vibration is a known problem with the brand of tires I run. Falken ZE512's.
Old Aug 9, 2005 | 09:38 AM
cardana24's Avatar
Blown
if its not an engine vibration then I would say your wheels are out of balance or you have some choice tires. If it is an engine vibration, it could be the maf flaking out or a misfire.
*also I see you are from Richmond VA, we have a meet coming up there this month. Check out the Local forums United States>>DC area and check it out.
Old Aug 9, 2005 | 09:55 AM
86maxima96's Avatar
I Broke OT
sorry, kinda a side note, but my car also vibrates slightly at hight speeds, but a lot while under hard braking. is that from warped rotors? (how easily do they really warp?)
Old Aug 9, 2005 | 10:19 AM
mindlessoath's Avatar
i say i could be tires... make sure to close all the windows for reduced drag too.
mabe increasing downforce will reduce this problem? i myself get alittle of this but i need new tires and i belive thats my only problem, wont know 100% until i get them tho.
engine mounts are the only other thing i could think of. replace them with poly ones.?
Old Aug 9, 2005 | 10:25 AM
poly's vibrate more. i have bad mounts (5spd) and it doesnt vibrate at all
Old Aug 9, 2005 | 10:37 AM
cardana24's Avatar
Blown
yes, you have warped roters
Old Aug 9, 2005 | 11:13 AM
Nissan 6's Avatar
Originally Posted by 99Automagic
strange....
I just got the falken 512 and there is no vibration problems going that speed or maybe its just me
Old Aug 9, 2005 | 11:16 AM
i think you have to put some miles on them first. when i was searching for my tires i know that they were hard to balance right or something like that
Old Aug 9, 2005 | 11:18 AM
99Automagic
About a yr ago, or maybe a little bit more, when those tires came out, alot of people were having vibration and balancing problems. There were alot of reports of this issue, and I was one of them who experienced it. I still have them on the car. Over time, it got better, but it's still noticable. I'm sure they corrected this problem by now.
Old Aug 9, 2005 | 03:16 PM
kasemodz's Avatar
yeah thanks guys, I think its the tire, because I have about 15% tread on em. I'm gonna change em soon, plus I didn't put air in them since November, so I should do it soon. Mine are the Bridgestone Touring Tires.
Old Aug 9, 2005 | 05:21 PM
Jatan's Avatar
Check the ECU for the knock sensor ghost code
user 11122324
42
Jul 18, 2022 03:35 PM
Apr 16, 2020 05:15 AM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
salty318
Sep 29, 2015 01:21 PM
