Bad Timing caused by????
Old Aug 9, 2005 | 01:11 PM
hdiggeddy's Avatar
My car has bad timing. It has trouble starting and the idle goes up and down frequently. I am not sure what can cause bad timing besides the cam sensor and crank sensor. Is there any way I can test these things with out buying a new one?
Old Aug 9, 2005 | 01:20 PM
f550maranello2's Avatar
is it throwing any codes? aka check engine light?
Old Aug 9, 2005 | 03:41 PM
i30ds's Avatar
Armed and Dangerous
How do you know its off?? Did you check it with a timing light?? The cam and BOTH crank sensors control the timing. Check the resistance of each sensor with a multimeter. The specs can be found in a haynes/chiltons guide. Try adjusting the base idle.
Old Aug 9, 2005 | 04:47 PM
aussie983's Avatar
Have you tried cleaning your throttle body?
Old Aug 9, 2005 | 04:48 PM
killerVQ30DE's Avatar
Check your Engine Coolant Temp Sensor too
Old Aug 9, 2005 | 08:53 PM
hdiggeddy's Avatar
Okay, I have checked everything. There are no CEL's, I am gonna try to find somebody else with a different maxima and try switching stuff over.
Old Aug 9, 2005 | 09:54 PM
i30ds's Avatar
Armed and Dangerous
Youre wasting your time! IF you checked everything and there is no improper signal being detected by the ECM, then switching things will accomplish nothing.
Your problem is something else. Its probably fuel retalted. Did you ever check the fuel pressure like I told you too in the other thread?? Try spraying some carb & choke cleaner in the throttle body and then start it up.
Old Aug 10, 2005 | 05:00 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
BAD TPS. so go do some work.
Old Sep 9, 2006 | 05:52 PM
airness_81's Avatar
O MY GOD help me with my car!!! Im running in freeway my car start to misfiring wat could be the problem any idea how could i test any of the problem im getting hard to get a code is there any more idea how to find the problem with my car?
Old Sep 9, 2006 | 06:48 PM
i30ds's Avatar
Armed and Dangerous
Creating complete sentences might help.
Old Sep 9, 2006 | 06:52 PM
jasonv's Avatar
are you missing? if your car is running rough pull one plug wire out at a time.if it stumbles put it back in and pull the next. if you pull one out and there is no change in the way the car runs thats the cylinder thats missing.
Old Sep 10, 2006 | 04:31 AM
njmaxseltd's Avatar
According to the Haynes shop manual, a hunting idle speed is definately an indication of a bad TPS.
It can also be caused by a faulty IACV, MAF or a vacuum leak.
Get a shop manual it will help you troubleshoot your car.
Matt93SE
May 24, 2019 02:58 PM
JoshG
21
Sep 4, 2015 09:04 PM
FlaMark
25
Aug 28, 2015 10:15 AM
JMag90
Aug 25, 2015 09:17 AM
doobadoo
Aug 15, 2015 06:43 PM
