Idea on modification of stock intake system
Old Aug 11, 2005 | 05:27 PM
Mymax97's Avatar
Hi
I dono if this has maybe been thought up before or what so im starting a thread. Im planing on making up this intake where it would just be an extension of the snorkle but with another source of cold air going to it. Basically take the stock box and hack that on the right side facing the car (i know thats been done). But then where the resonator is below the battery tray i took that off and will use what that is normally connected to and then under the car mount another snorkle upside down connecting to the original snorkles bottom. So that way when you are driving the cold air would kinda of come in from both places and then you would have the hole in the stock box for the short kind of hot air. Heres a link to my cardomain to show you kind of where im talking about and i think i might need to take a pic of the snorkle just so you can see the one part that goes downward to where the resonator box would hook up.
http://www.cardomain.com/ride/720766/5
Any ideas on how this would work out, should i even waste my time, or has it been tried before. Thanks for the input
-Tom
Old Aug 11, 2005 | 07:09 PM
Mymax97's Avatar
Hi
Bump for the night. Any inputs? Updated cardomain with words to show you clearler on how this would work.
Old Aug 11, 2005 | 07:21 PM
RA030726's Avatar
I'm nutty for Nissans
yea i have that on my 96, i think mzmtg has a write up some where or something. i used a piece of shop vac hose. fit perfect.
Old Aug 11, 2005 | 07:34 PM
Mymax97's Avatar
Hi
Do you have any pics from this type of setup. Also if you could find me the write up that would be awesome i dono what to look for on google to search for it.
Old Aug 12, 2005 | 04:14 AM
njmaxseltd's Avatar
Just take out the resonator box under the battery tray and drill a few holes in the side that faces twards the inner fender. That gives the stock setup another place to draw air into the system. Works great, I've had mine modded for a while now. There is no additional noise, nobody can see it so the engine bay remains clean and the gains are huge. Seriously don't bother with another tube, you only need to open up the stock setup slightly so the VQ can breath better up into the higher RPM's.
Old Aug 12, 2005 | 01:09 PM
RA030726's Avatar
well tom is correct unless you (well me) already threw away the stock parts
any how i dont have any pix but look up oscai and you should find it.
Matt93SE
May 24, 2019 02:58 PM
95Maxi
Aug 29, 2015 09:38 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Team STILLEN
Aug 10, 2015 04:29 PM
