How to clean Headlight lens?
Old Aug 11, 2005 | 05:31 PM
Obespalov's Avatar
Is there anyway to clean my dirty headlight lens. It looks yellow and someone made a comment on it yesterday. I know that I could probably use this as an excuse to buy the clear ones from the 99's, but I wanted to see if there was an innexpensive solution here first.
Old Aug 11, 2005 | 06:26 PM
Obespalov's Avatar
ok, scratch this post, I think I found a solution on google, let me ask my next question in another thread
Old Aug 11, 2005 | 06:27 PM
z32drifter's Avatar
You can find plastic polish at the local parts store. They sell a lens polish or if you find the polish for the plastic windows for a jeep or convertible it works the same. Should be under $10.00
Old Aug 11, 2005 | 06:33 PM
laylow1988's Avatar
i just did my driver side lens as you can see the discoloration in the pic and it looks stock now. the stuff i got was from pep boys and worked great. i will have to post the name tommorow cause i'm at my other job now and it is home.
Old Aug 11, 2005 | 06:36 PM
Obespalov's Avatar
Did u have to take off your headlight or do u clean the outside of the lens?
Old Aug 11, 2005 | 08:04 PM
ImmaSquashYou's Avatar
you don't have to take off the headlights, its only the outside. if you have to take it off that means you have to open up the head lights. unless you had a cracked headlight housing, usually not that much dirt and grime can get INSIDE the headlight
Old Aug 11, 2005 | 09:11 PM
RicoSuave98's Avatar
so do you have the glass 95/96 headlights? thats what it sounds like. im not too sure about those- haven't really had any experience there, but if you have the plastic lense like the 97/99s then i suggest miguire's #17 clear plastic polish. i got it at a specialty paint store for like $7, but i've seen it since at checker and auto zone for around $10. it works wonders and i use it all the time. its really great the more you use it the cleaner they come. its amazing
Old Aug 12, 2005 | 12:26 AM
Juice_818's Avatar
i have the same problem might get that maguire's...i heard you can buff them aswell..
Old Aug 12, 2005 | 05:01 AM
laylow1988's Avatar
thats the one i used the miguires what ever the spelling is .first wash the lens with soapy water then dry it then i just put some on the exterior let it sit for acouple of seconds and wiped it off then i did another coat just to do it but the first coat basically did the job.
Old Aug 12, 2005 | 10:50 AM
BourneJ's Avatar
I saw a thread once that mentioned "brake fluid", I'm not sure if it was a joke or if it really works. anyone recall anything like this?
Old Aug 12, 2005 | 10:52 AM
projectpete's Avatar
you can use nev-r-dull as well.
you apply it, let it sit for 15 mins, then it will look cloudy. then buff it off with a towel
Old Aug 12, 2005 | 12:30 PM
raycer911's Avatar
I use SimiChrome, a mildly abrasive chrome cleaner/polish -- it takes out not only the hazy, yellowed outer layer of the plastic lens, but also the hundreds of tiny sand pits that scatter and dim the light output. Works OK by hand, but even better with a buffer, where the mild heat generated softens the plastic and helps smooth out the sand pits.
Old Aug 12, 2005 | 03:28 PM
aussie983's Avatar
Novus 1-2-3 :d
Old Aug 13, 2005 | 03:10 PM
sharkulator's Avatar
Where do you get SimiChrome from?
Old Aug 15, 2005 | 07:09 AM
mattleo's Avatar
you can use mothers aluminum polish. its takes the yellow tint away i used it on my s97 240 those things turned yellow ever month untill i swapped them for s14
Old Sep 21, 2005 | 11:29 AM
WINO's Avatar
plastic polish at autozone works well
Old Sep 21, 2005 | 12:48 PM
l3ftonm3's Avatar
+1 on the meguiar's #17 works the best
AaronL
Nov 15, 2020 11:52 AM
Vistance
Sep 17, 2015 05:17 AM
mpbclutch33
Sep 8, 2015 06:21 PM
sdotcarter
Sep 2, 2015 09:53 PM
