Door Lock Remote Problem
Old Sep 21, 2005 | 12:21 PM
97BLKMAXSE's Avatar
I just replaced the battery in my remote for the door locks and tried reprograming it but it wont work. Everything with the car works when programing it but when i get to the last step, "push the lock button on the remote and the hazards will flash", the doors dont lock and the hazards dont flash. I have a second remote and tried to program that one and had no success. Has anyone else had this problem? Does anyone have any suggestions? Thanks
Tom
Old Sep 21, 2005 | 12:59 PM
njmodi's Avatar
Do I get a tax break?
Sounds like you might be either using the incorrect procedure or wrong remote ... here is the procedure again (just in case):
(If it still doesn't work, then your keyless receiver is probably not working. I'm not sure where that is located or if it's a part of the overall alarm/keyless control unit).
ID Code Entry Procedure
To enter the ID code, follow this procedure.
"Setting mode":
(1) Close and lock all doors.
(2) Insert and remove the key from the ignition more than six times within
10 seconds. (The hazard warning lamp will then flash twice.) At this time,
the original ID codes are eliminated.
ID code entry:
(3) Turn ignition key to "ACC" position.
(4) Push lock button on the new remote controller once (for example, if
door is locked using the remote controller during this ID code entry enable
state, a new ID code can be entered). At this time, the new ID code is
entered. (The hazard warning lamp will then flash twice.)
Additional ID code entry
(5) If you need to activate additional remote controllers, unlock the
driver's door, then lock again with door lock ****.
(6) Push lock button on the additional new remote controller once.
(7) This ID code entry enable state and setting mode remain until the
driver's door is opened.
NOTE
* If you need to activate more than two additional new remote controllers,
repeat the procedure "Additional ID code entry" for each new remote
controller.
* If the same ID code that exists in the memory is input, the hazard
warning lamps will flash twice but the entry will be ignored.
* Entry of maximum four ID codes is allowed and any attempt to enter more
will be ignored.
* Any ID codes entered after termination of the "setting mode" will not be
accepted. Additionally remote control signals will be inhibited when an ID
code has not been entered during the "setting" mode.
Old Sep 21, 2005 | 01:32 PM
97BLKMAXSE's Avatar
Those directions are a little different then what i have but those didnt work either.
intimidator
Sep 5, 2015 07:23 PM
trungg86
Sep 4, 2015 04:58 AM
Hailstatejig
Sep 2, 2015 06:52 AM
