Found this
Old Aug 17, 2005 | 10:28 AM
  #41
njmodi's Avatar
Do I get a tax break?
Originally Posted by lanky2882
What i do i disconect everything so the manifold is loose and then pull it forward a bit, after i pull it forward it makes that hose in the back visable and use needle nose plyers to pinch the clamp and pull it off. You only have to disconect the bottom side of the hose in the rear i leave the top side on (the side thats connected to the manifold). The nice thing about not taking those hoses off is you dont leak any coolant. The cylinder 1 injector is easy enough to get to with just pulling the manifold up about 5 inches. Just a tip if any1 has to do work on cylinder 1 save alot of time and having to clean up coolant :-)
I can usually get outer hose off no probs, but the hose that faces into the engine bay from the intake manifold to a hard metal tube is a b*itch - it's so short and I couldn't break it loose on the hard tube end - so I had to pull it off the manifold... I have to do the valve cover job (again) soon - so I'm looking for tips on those two hoses... everything else I can get to pretty easily... thanks for the input.
Old Aug 17, 2005 | 10:35 AM
  #42
lanky2882's Avatar
Getting it to "break its seal" is what makes it seem hard to me when i had to pull it off today i just moved the clamp pretty close to the one thats near the manifold and gave it a good twist kinda feels how a bolt loosens that first time u turn it and then after that just jiggle it off. Long needle nose plyers make it a whole lot easier since there's very little room back there.
Old Aug 17, 2005 | 10:38 AM
  #43
Stephen Max's Avatar
Originally Posted by Sounbwoy
I'd a never thought a bad PCV valve would make a car act that way...Still....please keep us informed. I'm real interested to see how this turns out...
Not the PCV valve but the air leak around it from the bad grommet.
Old Aug 17, 2005 | 11:11 AM
  #44
lanky2882's Avatar
Do u guys think this has been aiding to the missfire though? Thats been the problem ive been trying to fix since the beginning lol the injector fixed it for a like 2 hours but it came back
Old Aug 19, 2005 | 12:15 PM
  #45
lanky2882's Avatar
So i replaced that pcv seal today. Fixed the starting issue and the RPM drops but still lots of smoke. I also did an oil change today incase stuff got in my oil. Just puzzled dont know where the smoke could be comming. The smoke just smells like normal exaust nothing funky so dont think its anti freeze plz help
Old Aug 19, 2005 | 12:17 PM
  #46
njmodi's Avatar
How long did you let the car run - i.e. maybe you need to let it warm up and get to operating temp..
Old Aug 19, 2005 | 12:37 PM
  #47
Sounbwoy's Avatar
yeah. if the motor's running properly in terms of idling, I'd drive it to get it extensively (with someone following you, JUST in case) to get it warmed up.
BUT, is it still white smoke like in the pic you posted? You REALLY should get the compression test done bro....
Old Aug 19, 2005 | 12:43 PM
  #48
njmodi's Avatar
I agree on the compression test - its something you can do yourself very easily.
Old Aug 19, 2005 | 12:47 PM
  #49
lanky2882's Avatar
ya im going to do it this weekend. Car was warmed up was driving it around my area. I just hate my car lol why cant it be running good like all of urs :-)
Old Aug 19, 2005 | 12:49 PM
  #50
Sounbwoy's Avatar
Real quick. Is it sputtering WHILE you drive?
Old Aug 19, 2005 | 08:00 PM
  #51
lanky2882's Avatar
What u mean sputtering?
Old Aug 20, 2005 | 08:45 AM
  #52
Sounbwoy's Avatar
Ok. Is it misfiring as you drive?
Old Aug 20, 2005 | 11:22 AM
  #53
lanky2882's Avatar
Ya thats been the problem ive been trying to fix all along
Old Aug 21, 2005 | 03:26 PM
  #54
lanky2882's Avatar
But still i dont get where all this smoke can come from its not just a little when i start it up. It stays through driving and is a WHOLE lotta smoke any ideas?
Old Aug 21, 2005 | 03:47 PM
  #55
PAREDLINE's Avatar
I told you where it's coming from. You can ask 50 million times. Its either Oil or Coolant.
Most likely coolant. Change your head gasket before you crack the head or seize your motor.
Old Aug 21, 2005 | 08:16 PM
  #56
lanky2882's Avatar
Not coolant not Oil checked both had it running all this time levels for both havent changed and coolant would have a smell and the amount of smoke im getting it would have been eaten away at my oil and the oil is at the same level as a month ago so it aint that so why you gotta give me attitude like im an idiot
Is there anything else other than those two that cause smoke thats y i asked. Its going into the shop tomarrow anyways im tired of trying to find out why i got this miss ive tried everything
Old Aug 21, 2005 | 08:37 PM
  #57
ImmaSquashYou's Avatar
that sounds like a good idea...but make sure u go to someone u know....if not..then make its a reputable shop. the dealer will tell u whats wrong since they have to i believe, but a reg shop might not since they don't wnat to tell u whats wrong so u can bring it home n fix it yourself...
Old Aug 22, 2005 | 07:15 AM
  #58
lanky2882's Avatar
The place im going to is a bunch of hungarian guys that have always been honest with me. If its something cheap ill let them fix it just to save me the hastle just cant afford to pay a shop a couple hundred bux to do a head gasket or somethin
Old Aug 22, 2005 | 02:55 PM
  #59
PAREDLINE's Avatar
I wasnt trying to be a dicck but unless there's some new mystery fluid in our engines, that's what is causing it.
I doubt you pour water on top of your motor and it gets into the intake. It's gotta be either oil or coolant.
Old Aug 23, 2005 | 01:17 PM
  #60
Sounbwoy's Avatar
Lanky, have you found out anything yet?
Old Aug 29, 2005 | 10:15 AM
  #61
lanky2882's Avatar
Well got results today... no compression out of cylinder 1? What should i do not good news to hear. He says its prolly gonna be a lil more then 1000 to do or i could do myself
Old Aug 29, 2005 | 10:30 AM
  #62
njmodi's Avatar
It's time for a new engine. You can pick up a used VQ and either drop it in yourself or have it dropped in.
Old Aug 29, 2005 | 10:36 AM
  #63
Sounbwoy's Avatar
That $$ is for what? Head Work? Then yeah. Just go get another motor. Sorry about that man.
Old Aug 29, 2005 | 10:40 AM
  #64
lanky2882's Avatar
That money was to replace rings
Old Aug 29, 2005 | 10:41 AM
  #65
njmodi's Avatar
Unless you tear down, you don't know for sure if its the rings..
Old Aug 29, 2005 | 10:52 AM
  #66
lanky2882's Avatar
Ya i know it looks like im going to be tearing down myself and replacing rings if they need it and head gasket and end up selling the car
Old Aug 29, 2005 | 10:54 AM
  #67
njmodi's Avatar
Could also be a burnt valve or a hole in the piston... I'm wondering if you dropped something into the engine when you did the valve cover job (that started this whole mess).
Old Aug 29, 2005 | 10:58 AM
  #68
Sounbwoy's Avatar
Foggy memory, but doesn't the VQ using some special coating in the bores? Nikasil or something like that? See what the Engine forum has to say on it.
Also may to take a look at this for your own reading. The VQ is mentioned briefly..
http://www.nissanperformancemag.com/may04/nerds/
Old Aug 29, 2005 | 01:44 PM
  #69
lanky2882's Avatar
Ive been havin cylinder 1 missing problems for a long time though. Its very possible that its a ring and has always been one and ive just been beating around the bush. Im gettin a price from a friend of some1 i know who said he could hook me up. If he gives me a price like less then 500 and says he'll make it run right ill do it
Old Aug 29, 2005 | 03:10 PM
  #70
PAREDLINE's Avatar
Do a compression test again. Only this time put about 2 cap fulls of oil in the spark plug hole.
If you get compression then you probably have bad piston rings.
If you still get no compression, the lower end may not be whats wrong.
A leaky cylinder head gasket will give you 0 compression.
Old Aug 29, 2005 | 03:33 PM
  #71
lanky2882's Avatar
Thankyou that sounds very useful. Im waiting on a call tomarrow morning will help me know a little better where my car stands. He was givin me a price of like a grand to put in a 30k mile engine
Old Aug 29, 2005 | 03:59 PM
  #72
lanky2882's Avatar
What do you guys recomend depending on the problem. If its a head gasket? or Piston rings. Pay someone to do it what should be the limit i pay before i do it myself and should i just get a crate engine or pay for the rings or gasket to be replaced
Old Aug 29, 2005 | 04:00 PM
  #73
PAREDLINE's Avatar
Take the thing apart. You might get away with a $30 gasket
Old Aug 29, 2005 | 04:20 PM
  #74
lanky2882's Avatar
dont replacing piston rings need all these special tools to do like ring compressors and stuff? like i felt like it was a big enough pain doin the tube seals and the valve cover seals how much harder is this stuff?
Old Aug 29, 2005 | 04:23 PM
  #75
PAREDLINE's Avatar
Dude no offense. But go watch Karate Kid.
You Karate Do Yes-- Good
You Karate Do no-- Good
You Karate Do Ask Million Questions - Squish
Just take the junk apart. You wouldnt get coolant in your combustion chamber from bad piston rings. It's 95% likely something in the top end. LIKE THE FRIGGIN HEAD GASKET.
Look in a Haynes manual. Do a mental check to see if you can do this. Your engine is basically semi-toast as it is. What more can you do?
Putting 500 posts on this looking for answers when you can just open a simple manual and look at it - is worthless.
Old Aug 29, 2005 | 04:25 PM
  #76
njmodi's Avatar
You've already taken everything down to the heads apart before - so just work from there down... like PAREDLINE says, if you can't put sh*t back together, you are no worse off.. the car is not driveable as is, so if you end up screwing up, just get the new motor (you have that in your pocket as a backup plan either way). Why not chance it and try to fix it first.
Old Aug 29, 2005 | 04:31 PM
  #77
lanky2882's Avatar
I dnt like u paredline u always make me feel like an idiot cause im lazy lol. =) ya its my parents pushin me to pay some1 to do it for me not me. It looks like im going to do it myself unless i get a really good deal. I read the haynes manual it never makes me feel confident in how hard or easy something is. Everything seems so damn easy till u go to do it. I was just curious whats your oppinions on how much more it is i dnt know if u guys have done it yourself or not. Removing the plenum isnt really much for me anymore had to do that so many times. Out of everything the thing i hate most is having to get those tube seals back over the tubes when putting the valve cover back on. do you guys have any tips on that part of it?
Old Aug 29, 2005 | 04:32 PM
  #78
PAREDLINE's Avatar
Look back in the posts. I gave you the advice to check your head gasket a long time ago.
There are people with experience on these boards. You dont listen to them. You just re-post and re-post and re-post.
You're like some of my crackhead patients who do crack against medical advice then come into your office to cry and say how much their life sucks without any teeth....
How do I unsubscribe from this thread by the way?
Old Aug 29, 2005 | 04:35 PM
  #79
njmodi's Avatar
Unless you are putting the seals in upside down, they shuold just slide over the metal spark plug chamber tube... i.e. seat them into the valve cover, and then when you turn the valve cover around, the seals should be seated so they taper towards top of the valve cover, not the underside...
  #80
njmodi's Avatar
It will be in your profile under subscriptions.
