Muffler or cat?
Old Aug 15, 2005 | 04:10 PM
walshy's Avatar
Muffler or cat?
I just started to hear some noise comming from under my car, it sounds like I have a hole in my muffler. When i go up hills i hear a rattle under my car too, is that the cat? I got under it today and it sounded like the noise was comming from the middle of the exhaust system and not the muffler. Tell me what you guys think!
THANKS
Walshy
Old Aug 15, 2005 | 04:18 PM
PAREDLINE's Avatar
I think you should go to a muffler shop. I know... call me crazy. Just a thought.
PAREDLINE's Avatar
By the way. Cats go 'meow' not rattle
Old Aug 15, 2005 | 04:25 PM
walshy's Avatar
If i know what it is i can fix it by myself, i just wanted to ask everybodys opinion. if its not the muffler, what else can it be other than the cat?
Old Aug 15, 2005 | 04:28 PM
PAREDLINE's Avatar
It can be lots of things that someone would need to look at to tell you. Off the top of my dumb head it could be
1) pipe- broken, rusted, bent
2) flange
3) a broken exhaust mount/bushing
4) loose heat shield
5) broken heat shield
6) Anything else under the car
We cant tell on the internet dude. Most muffler shops will put it up on a lift and give you an estimate for free. Take the estimate and do it yourself.
Old Aug 15, 2005 | 04:29 PM
Loe max's Avatar
10char
Old Aug 15, 2005 | 04:31 PM
walshy's Avatar
it sound a honda...i gotta get this **** fixed soon lol
Old Aug 15, 2005 | 04:34 PM
zander's Avatar
If you get close enough and listen carefully you should be able to pin point where it is. Is it the stock exhaust? Only other thing is the resonator. Looking at the exhaust it looks like the cat is in the middle of the exhaust, I may be wrong though. Maybe that cool shield thing on the thing i think is the cat is loose or rattling?
Old Aug 15, 2005 | 04:37 PM
walshy's Avatar
yea it is still stock exhaust. It definetly is comming from the middle somewhere. So you think the cat or the resonator? Whatever the problem is its getting louder, so ill be checking it out tommorow and see whats up.
Old Aug 15, 2005 | 05:02 PM
zander's Avatar
Maybe even check for leaks, just run your hand down the pipe, not on it obviously. If you hear a constant puff puff puff noise there is a hole somewhere. Rattling I'd guess to be the cat.
Old Aug 15, 2005 | 05:23 PM
YoKramer's Avatar
2) flange
Best advise you could get ... Take it somewhere. There are many different things that could be leaking. My 97SE is leaking from the rear flange before the muffler. If you can get it high enough to get under there you should be able to pin point where it is coming from.
Old Aug 16, 2005 | 08:12 PM
Neem's Avatar
I had exhaust midpipe on my 96 GXE replaced today by local repair shop ($300). Six months prior I had my muffler replaced including muffler hanger. Had to have it looked at because the rattling and strange noise underneath my car while driving was driving me insane! Its a good chance that your exaust needs a few replacements.
Old Aug 16, 2005 | 08:13 PM
Black Maxima
Drive your car up on ramps and check out the situation.
Old Aug 17, 2005 | 05:25 AM
walshy's Avatar
Thats what i did, it was my cat. Changed it and all done!..now to get a muffler because that thing is rottin away
Old Aug 17, 2005 | 06:29 AM
sdoherty_tjm's Avatar
cherry bomb turbo II muffler. $18.99, and no resriction!
Old Aug 17, 2005 | 06:35 AM
PAREDLINE's Avatar
I haven't had any good experiences with the cherry bomb as a main muffler. It works as a cheap resonator.
Depends what you're looking for with sound. I like the car to have a nice rumble without waking up the neighbors.
The dynomax super turbo and 2.5" pipe worked for me on my maximas. Now that I have an I30 I want silence. Maybe i'm getting old.
Old Aug 17, 2005 | 06:43 AM
thats what the turbo II is like. at least it has baffles while maintaining performance (i.e. no resriction). i bought my max with a gay *** fart cannon, then cut it off and put this on, its like silent now. well, silent at cruising speeds, but then again, i dont have a y-pipe yet. i ordered my cattman y and its on backorder for like 4 weeks.
i wanted silence too. maybe i'm getting old too
maxinout93
Oct 31, 2015 02:04 AM
lrb6805
Sep 18, 2015 07:07 PM
TheMafia
Sep 4, 2015 08:26 AM
