Help!!!!! Clutch Will Not Disengage
Old Aug 19, 2005 | 07:44 AM
PTownMax's Avatar
I still miss the max
it won't go into gear when car is on and if you put it in gear and crank it up it tries to move without giving it any gas, also cannot pull it out of gear while car is on
any ideas?
Old Aug 19, 2005 | 08:37 AM
s0ber's Avatar
friend had the EXACT same problem, can you turn it on and get off in 1st gear, we did that and then all the gears got unstuck and worked perfectly normal..... Weird.
Old Aug 19, 2005 | 09:10 AM
matty's Avatar
any ideas?
Sounds to me like you need a clutch.
-matt
Old Aug 19, 2005 | 09:14 AM
max2di4's Avatar
Change to see if you have fluid in the clutch master and also check if the top of the gear box is wet with fluid. I have the same problem and I had a leak.
Old Aug 19, 2005 | 09:36 AM
s0ber's Avatar
did u fix it? try what i said.. lol its ghetto but it worked
Old Aug 19, 2005 | 09:37 AM
Loe max's Avatar
Can you pull it out of gear when the car is off?
I'm thinking there is no fluid in your clutch slave.
Old Aug 19, 2005 | 11:05 AM
PTownMax's Avatar
it's sitting in vortecpower's garage and yes, i tried moving it in gear but then it won't even let me go into neutral, i think the clutch is f***ed so i ordered an exedy and it should be here in the morning, yes the only way to change the gears is while the engine is off
Old Aug 19, 2005 | 11:08 AM
PTownMax's Avatar
i'll try and take a look at the clutch slave when i go over there today, also gonna adjust clutch pedal bar(adjuster) and see if i can gete anything out of that
Old Aug 19, 2005 | 02:34 PM
Fulltone74's Avatar
I had this same problem. It turned out my master cylinder had a leak. It was helped temporarily by adding some fluid and pumping the clutch pedal many times. After replacing the master cylinder, problem went away.
Old Aug 19, 2005 | 02:44 PM
PAREDLINE's Avatar
Sounds like a hydraulic problem. My first guess would be the slave cylinder. Try to pull the pedal back with your hand. It should pop right back.
Old Aug 19, 2005 | 02:54 PM
PTownMax's Avatar
still havne't gotten over there i'm waitin on my girl for a ride, already purchased clutch so i might as well swap while i'm doing all that, i'll try and bleed her tonight and see what happens
Old Aug 19, 2005 | 03:23 PM
PAREDLINE's Avatar
Its great that you got a clutch. But you can replace the clutch and nothing will be fixed. The hydraulics still wont work right.
Old Aug 19, 2005 | 07:58 PM
Loe max's Avatar
10char
Old Aug 20, 2005 | 06:39 AM
4thgenx42's Avatar
Our cars suffer from a leaking slave cylinder hose. Check the fluid in the clutch reservoir. If it has sufficient fluid, then its a possiblity the throw out bearing must have ed. I had the same problem about a 2 months ago, and now my brothers car is in the shop for the same reason. His is b/c the throw out bearing broke. So hes replacing the whole clutch. I had no fluid in mines and had to bleed for a very long time to get all of the air out of the lines...
Old Aug 20, 2005 | 03:06 PM
PTownMax's Avatar
i got throw out and everything, we're gonna replace clutch and all as soon as bijan gets over here, i'll make sure to check for any leaks
Old Aug 21, 2005 | 08:12 AM
PTownMax's Avatar
well we ran into may a problem with bolts w/ lock tight so we are now starting day2, i'll keep you posted
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
