Timing Chain Cover
Old Aug 19, 2005 | 01:34 PM
Dexter's Avatar
Timing Chain Cover
Is there anyway to remove the timing chain cover without unmounting the whole engine? And does replacing only the tensioner cause any problems due to the offset?
-Dexter
Old Aug 19, 2005 | 01:58 PM
maximus_96's Avatar
you don't need to remove the cover to replace the tensioner. you can access it thru one of the access holes on the side. the problem i had when i tried to replace mine was that the replacement didn't fit...i end up putting the old one back on...
Old Aug 19, 2005 | 03:56 PM
Dexter's Avatar
yeah but the bulletin says you need to replace both the tensioner and the gear to fix the rattle problem, will replacing only the tensioner do it?
-Dexter
Old Aug 19, 2005 | 04:12 PM
PAREDLINE's Avatar
taking the engine off its mount isnt a big deal. Just put a scissor jack under the oil pan with a 2X4 on top of it. Then unbolt the mount. You can raise and lower the scissor jack too. Or a floor jack...
Old Aug 19, 2005 | 05:31 PM
maximus_96's Avatar
-Dexter
supposedly, replacing just the tensioner will fix the rattle. when you order the parts from nissan it comes with the chain guide as well. you can't replace the guide thru the access hole. the new tensioner worked with the old guide for other people, but didn't for me.
Old Aug 19, 2005 | 05:45 PM
Dexter's Avatar
did you contact them about it?
-Dexter
Old Aug 19, 2005 | 05:47 PM
Dexter's Avatar
Wouldn't the weight of the engine crush the oil pan?! And working on an engine outdoors is a B*tch, even somthing as simple as an oil change seems like a daunting task in 90 degrees, but knowing that the local mechanic is trying to screw me over is even more daunting
-Dexter
Matt93SE
May 24, 2019 02:58 PM
Matt93SE
Apr 8, 2018 09:23 AM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
maxinout93
Oct 27, 2015 01:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
