Jerking.......
Old May 24, 2001 | 08:27 PM
NISMOPower's Avatar
While i'm driving just regularly i feel a jerk every time it switches gears. It is kinda rough...Does that mean something is wrong with my trans. Do i need to replace it or whats up???
Old May 24, 2001 | 10:03 PM
BippuBenji's Avatar
I'm guessing you have an auto like me, well, I had the same problemand what I did to solve that was a simple drain and refill. Now it feels a lot smoother. I also installed a tranny cooler to make sure it'll last longer.
Old May 25, 2001 | 06:53 AM
Daniel B. Martin's Avatar
Check your dropping resistor
Please check your dropping resistor. This component is mounted on the front side of the drivers-side strut tower. It has a gray plastic connector with two wires. This test is made with the ignition off. Disconnect the connector and use an ohmmeter to measure the resistance. It should be about 12Kohms.
Old May 25, 2001 | 10:58 AM
mzmtg's Avatar
Minister of Silly Walks
Re: Check your dropping resistor
Originally posted by Daniel B. Martin
Check your dropping resistor. This component is mounted on the front side of the drivers-side strut tower. It has a gray plastic connector with two wires. This test is made with the ignition off. Disconnect the connector and use an ohmmeter to measure the resistance. It should be about 12 ohms.
Mine's always been 12 Kohms
Old May 25, 2001 | 11:16 AM
Thank you for the correction
Thank you for the correction. My '99 Maxima factory service manual says Resistance: 11.4-12.6 ohms. My own Maxima is a 5-speed so I can't make a personal cross-check. I believe your number is right and the FSM is wrong. I've found other mistakes.
Old May 25, 2001 | 01:34 PM
gtr_rider's Avatar
192.168.1.1
how much did it cost to drain and refill the tranny.
Old May 25, 2001 | 01:44 PM
BippuBenji's Avatar
It should only cost about 4-5 quarts of tranny fluid depending if your going with synthetic (costs a little more). I can't talk for the 5-spd, but I know its pretty easy to the DIY mechanic, just a simple removal of the drain plug. The tranny fluid should consist of 10 quarts, but a simple drain and refill will only drain about half of it. To get almost all of it, you can try the drain and refill about 3 times to make sure all of the older fluid is gone.
Old May 25, 2001 | 02:23 PM
gtr_rider's Avatar
192.168.1.1
why would you only get 4-5 quarts if the tranny holds 10 quarts???
Old May 25, 2001 | 02:47 PM
Torque converter
Draining the transmission pan does not drain the torque converter.
Old May 25, 2001 | 04:27 PM
gtr_rider's Avatar
192.168.1.1
Re: Torque converter
ok, thanks for clearing that up.
Old Mar 27, 2008 | 03:16 PM
maxima278's Avatar
my car sounds like a truck on knobby tires after the engine was swapped out. You think it could be a tranny or torque converter problem? How do you get fluid to cycle into the torque converter?
Old Mar 27, 2008 | 08:29 PM
heynow's Avatar
that's a very vague description dude
Old Mar 27, 2008 | 08:30 PM
heynow's Avatar
Dan, if the drop resistor bad.......and is the reason for the roughnes... isn't that a good thing? (for longetivity purposes?)
Old Mar 27, 2008 | 09:24 PM
max ride 41's Avatar
any pic of that part??? i just had a tranny swap and it does the same thing and i replaced 2 mounts, 1 trans mount and 1 engine mount. and its still jerkin on me when i shift but not real bad, mounts helped. auto as well...
Old Mar 29, 2008 | 12:04 PM
DBear's Avatar
It's really easy to find. It sits right there on front of the strut tower mount, right next to the air filter housing.
If you check it, let me know your reading. I got 12.5 ohms, as per the FSM, not Kohms, like the earlier posters said. But someone bumped a 7 year old thread, and I don't think Daniel Martin has been around for some time, so I can't ask him...
Old Mar 29, 2008 | 02:48 PM
bigpulve+'s Avatar
Holy old thread batman....
Old Mar 29, 2008 | 02:57 PM
garyrr's Avatar
............off?
Posts: 10 <-----------that explains it
