Referring To Camber Kits
Old Aug 19, 2005 | 09:14 PM
zzmasta06's Avatar
Hello maxima lovers, i need your help!
i took my car to the mechanic for an alignment check, and the mechanic showed me my lower control arm (r side) and he said i gotta buy a new one, with a camber kit.
So question is
1.I heard that camber kits can help me lower my car also?
2. If I lower my car, do i need a new set of camber kits for rear behind?
boy i love maximas which are lowered!
Old Aug 19, 2005 | 09:38 PM
A Flood99's Avatar
hmmmm, well you don't need a camber kit UNLESS you're lowered
if you're stock then you're fine, just replace the lower arm and get another alignment
However, if you plan on lowering a camber kit can come in handy but isn't necessary
I am lowered 2.2" up front and am not running any camber bolts.......but i'm sure my camber is whack
Old Aug 19, 2005 | 10:05 PM
86maxima96's Avatar
I Broke OT
didn't you get an alignment after the drop??
Old Aug 19, 2005 | 10:55 PM
chenzarino's Avatar
I have 4 camber bolts new in box that adjust +/- 2 degrees camber PM me if youre interested.
Old Aug 20, 2005 | 05:39 AM
4thgenx42's Avatar
Where can I get a camber kit?
Old Aug 20, 2005 | 09:31 AM
A Flood99's Avatar
yeah of course, but they couldn't do much with my camber considering my drop
Old Aug 20, 2005 | 09:48 PM
zzmasta06's Avatar
refering my question
so do i need rear camber kits to lower my car? or just the fronts?
Old Aug 20, 2005 | 11:14 PM
chenzarino's Avatar
no the rear is not adjustable and shouldnt get out of whaxk.
Old Aug 21, 2005 | 03:21 AM
browne's Avatar
i would get another check-up from a different mechanic about changing the lower-arm. i got ripped off by this shop when he never even changed it. i caught him lieing since i forgot to give him my wheel lock key which he would need to get access to the lower arm. fooking mechanics!
Old Aug 21, 2005 | 05:28 AM
maximariceboi's Avatar
hmmm...yea..i need to get my alignment done. So there is no adjustment on the rear? save me some money because the guy was telling me i need all 4 wheels aligned because its lowered.
Old Aug 21, 2005 | 10:50 AM
zzmasta06's Avatar
i really hate mechanics that lie, and cheat your money,
im lucky that my pops is best friends with the mechanic, which doesnt charge my dad no money.
one more question
1.If i lower the front portion of the car, how would the rear be lowered also? wouldnt it look funky? having the rear high, and the front low?
or does the front camberkit also lower the rear
Old Aug 21, 2005 | 11:07 AM
browne's Avatar
one more question
the camber kit has nothing to do with lowering the car. you lower the car by buying after-market springs which are usually lower then your stocks. once the car is lowered, your alignment is mostly going to be off. the camber kit will help you align only the front tires to stock specs.
Old Aug 21, 2005 | 12:13 PM
RA030726's Avatar
I'm nutty for Nissans
if you need camber adjustment drill out 1 of the 2 lower holes in the strut.
Apr 16, 2020 05:15 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Pied
Sep 26, 2015 03:29 PM
