Confusing Gas Milage
Old Aug 21, 2005 | 10:54 PM
gto400no1's Avatar
I dont know if this sounds odd or not but it sure seemed so to me. usually i get poor milage, usually around 16-18 mpg when mostly city and some highway. i do not drive my car hard, rarely i go over 3k rpms. now the other day i drove the car just on highway between tanks and i got 30 mpg. why would there be such a change when other times i have made trips where it was all highway i usually got like 24 mpg. is there somthing thats not functioning right or is this just normal. granted the 30 mpg trip was no city driving and very few stop and goes. so maybe thats why its beter then ever but it just seems like to big of a difference tho. what you guys think?
Old Aug 21, 2005 | 11:03 PM
matty's Avatar
Did you switch where you bought gas from ??
-matt
Old Aug 22, 2005 | 04:36 AM
PoKKi's Avatar
For some odd reason I actually got better mileage with Esso fuel. I tend to use Shell a lot and the gas mileage is usually pretty stable for Shell, around 16 - 18MPG (mostly 18 in the summer months and 16 in the winter) but I was able to get 22MPG mostly city on some regular Esso.
But in any case don't worry about it.
Old Aug 22, 2005 | 04:39 AM
4thgenx42's Avatar
It can depend on where you pumped or how youre stepping on the throttle. Try changing your fuel filter...
Old Aug 22, 2005 | 08:55 AM
sampdoria's Avatar
your reading could be very inaccurate. and you should use the same pump to get the estimate of gas used.
Old Aug 22, 2005 | 11:55 AM
4banger69's Avatar
change air filter, spark plugs, and un fuel system cleaner, you should see a difference
Old Aug 22, 2005 | 12:14 PM
gto400no1's Avatar
i bought that gas at a diff gas station then usual, but its still the same company (wawa) i was on vacation to the poconos and i stopped to get gas there. i usually use the wawa gas from the wawa i work at. i have changed most of the things that would fix milage, air filter, spark plugs, fuel filter, o2 sensors, cleaned throttle body, changed oil, checked air pressure. only things i havent done yet are knock sensor, coil packs, pcv, and egr. i have tryed different stations (mobil) but saw no change in my milage.
Old Aug 22, 2005 | 12:40 PM
greengrass215's Avatar
weather condition and driving up mountain affect mileage also. i don't think what gas station you go to affect mileage unless they giving you less than what you paid for.
Old Aug 22, 2005 | 12:59 PM
udienow's Avatar
Your problem may be your KS. I just replaced my KS, TPS, and fuel filter, and one of those increaced my gas milage by alot. The most i got before was 340 to a tank 1 time driving granny styled. I am now in process of my first tank after changing these 3 things and am at 300 miles with just over 1/4 gas left, predicting to hit at least 400 this tank for the first time.
Old Aug 22, 2005 | 02:32 PM
Mr.Duck's Avatar
um... wtf is wawa?? lol i usually get 24mpg on regular driving, closer to 30 when its pure highway
Old Aug 22, 2005 | 03:51 PM
Bobo's Avatar
More than one stealership has told me that they don't have problems with the PCV valves like years ago and seldom change them. I take it your PCV valve has never been replaced. What mileage does your car have?
I've just turned 60K and my car does not hesitate at all which is a symptom of a PCV valve that requires replacing.
Old Aug 22, 2005 | 04:47 PM
DragonMaxima's Avatar
Recently filled up gas and pumped in 16.9 gallons. My low gas light never went on. Is there a better way to find out if my light works?
I have a 95GXE. Not sure if this was an option or standard feature.
Thanks.
Old Aug 22, 2005 | 04:48 PM
7jackmack's Avatar
my sister's 4 cyl. Altima consistently gets only 13- 15 mpg in all city driving. I
borrowed it , filled up twice - same day- same station - same pump and got 40 mpg
ALL Highway.
Old Aug 22, 2005 | 04:51 PM
matty's Avatar
Thanks.
Are gas tanks are 18.5 Gallons. I believe it comes on during your last gallon sometime.
Originally Posted by 7jackmack
got 40 mpg
Impossible Sounds a little made up dont ya think
-matt
Old Aug 22, 2005 | 04:52 PM
7jackmack's Avatar
Note - as i said ALTIMA 4 cylinder - all highway - quite possible!
Old Aug 22, 2005 | 04:56 PM
matty's Avatar
Highly unlikely and YES I did Note that it was an ALTIMA 4cyl
-matt
Old Aug 22, 2005 | 05:06 PM
Bobo's Avatar
-matt
There is a disconnect between 40mpg highway and 13 - 15 city on the same car.
I can get ove 30 on my Maxima so perhaps 40 with the Altima 4 cylinder is not out of the realm of possbility, but seems like a stretch to me. The 13 -15 mpg is fubar, however.
Old Aug 23, 2005 | 10:44 AM
-matt
Thanks. But is there a quick way to find out if the light actually works without having to actually run it down so low?
D Mason
Jun 21, 2016 04:43 AM
AboveDaCloudz
Oct 8, 2015 11:25 PM
ef9
Oct 4, 2015 08:43 AM
