front end specialists...
Old Aug 23, 2005 | 03:21 PM
Stuntin' 101's Avatar
control arms, inner and outter tie rods, stabalizer links, bearings, rotors, struts, strut mounts.. what else is there that can be chaged that can/does affect the way the car drives/rides..
Old Aug 23, 2005 | 03:28 PM
Jeff92se's Avatar
I'm needing a caw
Ball joints
Old Aug 23, 2005 | 03:29 PM
MDeezy's Avatar
his control arms come with new ball joints.
Old Aug 23, 2005 | 03:31 PM
Jeff92se's Avatar
I'm needing a caw
Where?
Old Aug 23, 2005 | 03:32 PM
THEJEFFERATOR's Avatar
good strong strut tower braces, never believed it till i tried it
Old Aug 23, 2005 | 03:34 PM
MDeezy's Avatar
Originally Posted by Jeff92se
Where?
Thats the ball joint. . . . . . . . right?
Old Aug 23, 2005 | 05:13 PM
njmaxseltd's Avatar
Tires, especially the profile height.
Old Aug 23, 2005 | 05:46 PM
2 Da Max's Avatar
so thicker profile equals smoother ride?
i have 2245s r 17
Old Aug 23, 2005 | 06:03 PM
NY 95 VQ30DE's Avatar
Yes, thicker profile = thicker sidewall = softer ride.
Like if i put 235 65 ZR17's on my car instead of the 235 45 ZR17's that are on it, ride quality (softness) would improve at the expense of handling.
Old Aug 23, 2005 | 06:38 PM
nick's Avatar
worn out and loose steering rack will give you sloppy ride >>>>
are you still unhappy with the way your car rides ???
Make sure that you torque down those sway bar endlinks to proper specs
which is 16-20 Ft lbs, those little bushings have huge impact on how the car handles and feels
And i highly recommend OEM rubber bushings for sway bar endlinks
the handle just as good as ES suspension , but without all that unwanted harshnes and nervousness in steering wheel
Nick.
Old Aug 24, 2005 | 05:03 PM
Nick.
im gonna be unhappy with the way my car rides until i buy a benz but i might as well make it as good as i can get it
Old Aug 24, 2005 | 05:04 PM
MDeezy's Avatar
or move to a city with better streets
Old Aug 26, 2005 | 02:48 PM
mxm's Avatar
mxm
Can you replace only the ball joints or must you replace the control arm as a unit with preintalled ball joints?
Old Aug 26, 2005 | 03:55 PM
d00df00d's Avatar
Old enuf to pick his own gears
Springs, FSTB, LTB, wheel/tire weight, tire balance, alignment.
Old Aug 27, 2005 | 09:09 AM
lewtion1's Avatar
you can do both... but why not just replace the whole thing since the new control arm comes with bushings as well
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
GregL65
Sep 5, 2015 09:37 PM
jfl330
Sep 4, 2015 01:44 PM
