Brake and rotor install questions
Old Aug 26, 2005 | 05:23 AM
McNasty360's Avatar
Hey guys I just got four new nissan rotors and I'm going to put them in today, I was wondering if I should get them cut into or is it cool to just put them on right out of the box. Thanks in advance
Old Aug 26, 2005 | 05:29 AM
crazy97's Avatar
They should be ready to go, make sure you spray them down with brake cleaner to get that protective coating off.
Old Aug 26, 2005 | 05:31 AM
McNasty360's Avatar
ok thanks, I was wondering what that oil was and why they would be on brakes.
Old Aug 26, 2005 | 06:44 AM
njmodi's Avatar
Do I get a tax break?
The coating is to keep the rotors from rusting while on the shelf.
Old Aug 26, 2005 | 07:43 AM
mmlloo's Avatar
I just got mine replaced 1 month ago. I noticed that the new OEM rotors didn't have the 2 threaded holes on the rotor so that in case the rotor is stuck on the hub, one can screw in a bolt to push out the rotor. The old rotors had them. I thought that was the only distinguishing useful appearance difference between OEM and aftermarket rotors. I guess Nissan wanted to save money by not drilling and tapping two holes on each new rotor.
Old Aug 26, 2005 | 07:45 AM
njmodi's Avatar
Are you sure? Where did you get the rotors?
PAY_ME96's Avatar
An anti-seizing agent will take care of that.... Mine came off easily...
Old Aug 26, 2005 | 01:02 PM
mmlloo's Avatar
I bought them from a nissan dealership in CA. They came in Nissan labeled boxes (rotors/pads), so I didn't think they were aftermarket ones. I did end up applying a thin film of anti-seize compound on the hub. Hopefully that will do the trick.
Old Aug 26, 2005 | 01:13 PM
MaximaSE96's Avatar
Maxima Owner
thats what hammers are for.....anti-seize is just as good....i also like to derust the hubs with my die-grinder as well
Old Aug 26, 2005 | 01:22 PM
crazy97's Avatar
Anyone know what size that hole is on the rotors? Mine are stuck on and I need to find a screw to stick in there.
Old Aug 26, 2005 | 02:02 PM
udienow's Avatar
Rotors just come right off... once you get the caliper and all that off and u got nothing but the rotor... it just slides off... with a great force of course. I had to bang mine with a hammer for a bit to get em off but they came off. Just changed mine last nite. I hope u didnt pay too much for them nissan rotors, as theres a GD for brembo blanks for $36 a rotor....
Old Aug 27, 2005 | 11:43 PM
mmlloo's Avatar
Ahh! I got ripped at around $60/rotor (which was already about 25% lower than retail) for the "genuine" Nissan rotor. I suppose it doesn't really make much difference since it's really just a chunk of steel.
Old Aug 28, 2005 | 06:10 AM
wahoohead's Avatar
not always
Rotors should come off with a big enough hammer, but it is somtimes hard to get a big enough swing. The bolt hole on the factory OEM's makes it very simple. I could not swing big enough or hard enough to do it with a hammer. I had a spare bolt kicking around that happened to fit.
Old Aug 28, 2005 | 10:21 AM
dual's Avatar
Just to add to the above...
De-rust the hub, check/lube the guide pins (had one seize on the GF's car, love that dealer), anti-squeek (if the pad backings are metal), clean it all up and torque the wheel back to specs.
rbuswell
Nov 17, 2016 04:54 AM
03VQMAX
Sep 25, 2015 04:19 PM
homeyclaus
Sep 3, 2015 06:15 PM
RealityCheck
Aug 5, 2015 06:18 AM
