Need help finding wire...
Old Aug 26, 2005 | 01:42 PM
DuMKuH's Avatar
Hey guys, I have gone through all the threads and stickies about the starter kill switch and want to make one, but have a problem finding the right wire to make it start with some stock button, I was trying to download manual using stickies but no luck, since the links are dead. So, I would like to ask if you can help me with link on manual for the 98 max and pointing the starter power wire(is it the black with green?). Thanks in advice and any advice about the starter kill switch will be helpfull.
P.S. I have read this thread already(thanks for replies sean05 ): http://forums.maxima.org/showthread.php?t=420114
Old Aug 26, 2005 | 09:31 PM
DuMKuH's Avatar
anyone?
Old Aug 26, 2005 | 09:34 PM
speed racer's Avatar
Try this site. It might help you out. I was checking it out b/c alot of people been getting there cars stolen in NYC
http://www.the12volt.com/carsecurity/carsecurity.asp
Old Aug 26, 2005 | 10:58 PM
PAREDLINE's Avatar
You have to use a relay. This is a good article http://www.the12volt.com/relays/page2.asp.
Use the passive starter kill.
Old Aug 27, 2005 | 03:14 AM
DuMKuH's Avatar
Thanks guys!!
Old Aug 28, 2005 | 04:10 PM
DuMKuH's Avatar
Do you know where I can find diagrams to find out which wire is which to find the right one?
Old Aug 28, 2005 | 04:12 PM
PAREDLINE's Avatar
MODEL YEAR(S)
MAXIMA 1995 -1999
KEY T-HARNESS IMMOBILIZER
N/A NIS-1 NISSAN'S TRANSPONDER ANTI-THEFT SYSTEM, Requires 791 Bypass Module and extra Ignition Key (See NOTE *3)
PART COLOR LOCATION DIAGRAM
12 VOLT CONSTANT WHITE/RED to WHITE/PURPLE (+) IGNITION SWITCH HARNESS
STARTER BLACK/YELLOW to BLACK/WHITE (+) See NOTE *1 IGNITION SWITCH HARNESS
STARTER 2 GREEN/BLACK to RED/BLUE (+) See NOTE *1 IGNITION SWITCH HARNESS
IGNITION 1 BLACK/WHITE to BLACK/RED (+) IGNITION SWITCH HARNESS
IGNITION 2 N/A
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 RED/YELLOW to RED (+) IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 BLUE to WHITE/BLUE (+) IGNITION SWITCH HARNESS
KEYSENSE N/A
PARKING LIGHTS ( - ) N/A
PARKING LIGHTS ( + ) RED/GREEN (+) @ STEERING COLUMN HARNESS
POWER LOCK LIGHT GREEN/RED (TYPE B) @ SWITCH IN DRIVERS DOOR
POWER UNLOCK GREEN/YELLOW (TYPE B) (Requires Double Pulse) @ SWITCH IN DRIVERS DOOR
LOCK MOTOR WIRE BROWN/WHITE (+) @ SWITCH IN DRIVERS DOOR
DOOR TRIGGER RED/WHITE (-) LOW IN DRIVERS KICK PANEL
DOMELIGHT SUPERVISION USE DOOR TRIGGER
TRUNK RELEASE PURPLE/YELLOW (-) LOW IN DRIVERS KICK PANEL
SLIDING POWER DOOR N/A
HORN GREEN/WHITE (-) @ STEERING COLUMN HANRESS
TACH WHITE/GREEN @ ECM, See NOTE *2
WAIT TO START LIGHT N/A
BRAKE RED/GREEN (+) @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM N/A
ANTI-THEFT See NOTE *3 See NOTE *3
NOTES
NOTE *1 When Installing a REMOTE STARTER, you MUST use BOTH Starter #1 and Starter #2 wires. Both wires must be connected to the STARTER/CRANKING Output wire from the Remote Starter or the vehcile will NOT Remote Start when the Engine is cold.
NOTE *2 THE ECM (Electronic Control Module) IS LOCATED IN THE FRONT OF THE CENTER CONSOLE ON THE TRANSMISSION HUMP.
NOTE *3 some late production model 1999 Nissan Maxima's are equipped with NISSAN's TRANSPONDER ANTI-THEFT SYSTEM, these vehicle will require a 791 Bypass Module and an extra Programmed Ignition Key when installing a Remote Start Unit.
Old Aug 28, 2005 | 04:30 PM
DuMKuH's Avatar
I can not find the right words to thank you
Old Aug 28, 2005 | 04:32 PM
PAREDLINE's Avatar
thats what we're here for
Old Aug 28, 2005 | 08:20 PM
I just did this today. If you want pm me so I can go over what exactly I did.
Old Aug 28, 2005 | 09:00 PM
DuMKuH's Avatar
You have got PM. Thanks
Old Aug 30, 2005 | 10:23 PM
DuMKuH's Avatar
One more question: can you guys tell me where is the fuel pump wire and which color it is...I know I should look for it somewhere around rear seats area... Thanks a LOT
Old Aug 31, 2005 | 11:15 PM
DuMKuH's Avatar
Nobody?
Old Sep 1, 2005 | 08:26 PM
PAREDLINE's Avatar
To get to the fuel pump electrics you have to remove the lower portion of the rear seat. Then you'll see a door with 3 screws attaching it. Remove those screws and you'll see the plug for the fuel pump.
I wouldnt mess with this because if you cause a spark either when installing it, or in the future if you dont install everything absolutely flawlessly, your car will explode.
You can use the fuel pump fuse and/or relay either under the hood or the dash to cut off fuel pump power.
Be safe not dumb.
Old Sep 1, 2005 | 10:36 PM
DuMKuH's Avatar
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
pears
Sep 18, 2015 05:25 AM
Vistance
Sep 17, 2015 05:17 AM
adamgalazka
Sep 8, 2015 01:27 PM
