120k service
Old Aug 29, 2005 | 01:00 PM
radicht's Avatar
120k service
I am changing the spark plugs, fuel filter, and doing an oil change. Is there anything else that I need to do at 120K?
Old Aug 29, 2005 | 01:04 PM
njmodi's Avatar
Do I get a tax break?
Tranny drain/fill/flush
Coolant drain/fill/flush
Air filter
PCV valve
Other:
Tire rotation
Check brakes
Check throttle cables for slack
Clean throttle body and idle air control valve
Old Aug 29, 2005 | 01:07 PM
Loe max's Avatar
On top of that
-change brake fluid
-check suspension allignment
-check CV boots
-change any hoses that are old
-check serpentine belts
And also, I would swap in a new thermostat to reduce the risk of over heating.
Old Aug 29, 2005 | 01:10 PM
mohmony's Avatar
Does the 4th Gen Maxima's / I30's do not have a Timing Belt / Water Pump that need to be replaced at around the 100K Mileage??
Pardon my Ignorance if the 4th Gen have the Timing CHAINS...
Old Aug 29, 2005 | 01:11 PM
njmodi's Avatar
We have timing chains.
Old Aug 29, 2005 | 01:12 PM
Loe max's Avatar
They have timing chains, but you should check the guides or teeths on them just to make sure every once in while. Its rare for a Maxima's water pump to fail near 100K miles. I do believe they have a metal impellar which is eeeyons sturdier than a plastic one (the the crap they put in my 'high' quality' german)
Old Aug 29, 2005 | 01:31 PM
High Altitude's Avatar
Speaking of 4th gen in the 120K range, has anyone had problems with their heater core?
I've been losing water in my 95 SE a very little bit at a time and in the winter months when I have heat selected I sometimes smell antifreeze after I shut the engine off and step outside.
Also, as soon as I drive off for the first time in the morning, I hear the trickle of water from somewhere under the dash and a musty smell. Nothing is ever wet under the dash so I'm not sure if its a leak in the core or some other problem.
Any advice appreciated.
Old Aug 30, 2005 | 03:10 PM
anyone have any info on this??
Old Aug 30, 2005 | 05:04 PM
bump......
my03maxima
Jul 28, 2024 07:40 AM
Excalibur23
Oct 13, 2015 04:33 PM
RealityCheck
Oct 2, 2015 06:34 PM
Max8
Sep 22, 2015 02:53 PM
Pixel
Sep 15, 2015 05:53 AM
