Testing a torque converter
Old Aug 29, 2005 | 10:32 PM
Xmax's Avatar
I pulled my trans from my car just a few hours ago, after pulling it out and looking at the torque converter i was thinking maybe my converter went bad with my tranny. Is there a way to test it at home or somewhere very cheaply? I know if you try to spin it one way it will spin freelly by putting your finger inside the converter and spinning the inside of it, but the other way doesnt spin. I did that to THT converter that he let me buy if my converter is bad, and it did do the same thing, but this is not under the car's load so i don't know if there is any difference. I don't want to put the tranny in and everything else in and realizing that the converter is broken and needs to be replaced.
Old Aug 30, 2005 | 06:46 AM
tavarish's Avatar
fwd gone rwd cr00
well usually to test the torque converter, you would have to have the tranny on, and torque brake.
Old Aug 30, 2005 | 09:11 AM
DAVE Sz's Avatar
Hooooooonda.....
Just use Ty's TC. There was nothing wrong with his trans when he did his swap and it has less miles than yours.
Old Aug 30, 2005 | 10:28 AM
f550maranello2's Avatar
a. Insert check tool into the groove of bearing support built into
one-way clutch outer race.
b. When fixing bearing support with check tool, rotate one-way
clutch spline using screwdriver.
c. Check that inner race rotates clockwise only. If not, replace
torque converter assembly.
Old Aug 30, 2005 | 10:50 AM
hectorc's Avatar
Upper Midwest Wheel Whore
WERD.........
tarun900
19
Dec 20, 2021 06:57 PM
knight_yyz
Nov 1, 2015 01:34 PM
09maxshawn11
Sep 30, 2015 10:28 AM
sliptap
Sep 30, 2015 05:57 AM
