Line Pressure Solenoid Valve (Automatic Transmission)
Old Aug 30, 2005 | 08:17 AM
Black Maxima
I disconnected the resistor for the Drop Resistor mod for a quick run to show my friends. As soon as I started the car I got a check engine light. This morning I got 5 Fast and 12 slow flashes, which means Line Pressure Solenoid Valve (Automatic Transmission). I reset the ECU, so we'll see if the lights goes away. If it doesn't go away, is it something that should be looked at right away?
Thanks, Aaron
Old Aug 30, 2005 | 08:21 AM
njmodi's Avatar
Do I get a tax break?
Did you reconnect the drop resistor? If not, reconnect it, reset the ECU and you should be set.
Old Aug 30, 2005 | 08:30 AM
Black Maxima
Yes, I disconnected it for a short ride. When I got back two minutes later, I reconnected it.
Old Aug 30, 2005 | 09:13 AM
f550maranello2's Avatar
reconnect the resistor and rest the ecu it will go away
Old Aug 30, 2005 | 09:17 AM
Black Maxima
Thank you!
Old Aug 30, 2005 | 12:04 PM
Black Maxima
The CEL is still on!
Old Aug 30, 2005 | 12:15 PM
you didnt erase the code correctly try it again...
Old Aug 30, 2005 | 12:40 PM
Black Maxima
Your right, I didn't. HAHAHAHA
Problem Solved!
Old Aug 30, 2005 | 03:41 PM
Black Maxima
Ok, I reset the ECU and the CEL was gone. Then, I left the house and it's back on again. WTF!
Old Aug 30, 2005 | 06:03 PM
MaximaSpd85's Avatar
the only thing with the dr mod, is that the code will come on, and ur o/d off light will blink 16 times, i dont know y urs came bak on....wen ur drivin does it shift as if the resistor was disconnected?
Old Aug 30, 2005 | 06:08 PM
NY 95 VQ30DE's Avatar
yeah, maybe you didnt plug it back in all the way??? Or bent a pin or
something.
Old Aug 30, 2005 | 06:34 PM
sunten1
Make sure you connected everything correctly. Because you prolly yanked a wire loose when you tried to dissconnect
Old Aug 30, 2005 | 07:09 PM
2 Da Max's Avatar
that code happens to me every so often aswell, i have the WOT switch, i guess when i push the car hard it appears..
Old Aug 30, 2005 | 07:18 PM
2 da max, how do you like your WOT switch on the resistor. Im thinking about hooking it up to a toggle switch instead, because i hit wot more often than i should.... That way i would minimize its use.
Old Aug 30, 2005 | 07:33 PM
Black Maxima
Thanks for the replies. The shifts seem a little harsh. I'll check it out tomorrow...
lowpost99
Oct 26, 2025 06:53 PM
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
boomerbrian
Oct 31, 2018 10:25 AM
videomano
Sep 8, 2015 03:28 PM
