Knock Sensor CEL and performance
Old Aug 31, 2005 | 02:58 PM
turbo
OK here is the deal: I got the KS code 2 weeks ago while driving. I had been putting in 91 octane at that point and I tested the KS and it all checked out fine at 560mV or something like that. I reset the code and put 94 Octane in - felt like I had gained back quite some power and the CEL stayed away. I then went back to 91 just to see and the light came back on and power seems to be lacking. So now I have 94 back in but have yet to reset the CEL.
My question is will I still get ****ty performance with the 94 until I reset the CEL?
Old Aug 31, 2005 | 03:06 PM
NmexMAX's Avatar
dot dot dot ...
The KS wont trip the CEL on its own..
Read the stickies
You probably have another code stored
Read the stickies
Pull your codes
[Read the stickies
Performance will suffer upwards of 20 whp
Read the stickies
And so will gas mileage
Read the stickies
Just because it "checks out" doesn;t mean it's good.
[Read the stickies
Old Aug 31, 2005 | 03:20 PM
turbo
Right...
VSS code tripped too
How do I go about checking the KS beyond measuring the resistance? Oh yeah, the wiring is all good too.
Old Aug 31, 2005 | 07:35 PM
sonicrunch's Avatar
Make sure you measure the resistance when it is hot...It tends to read normal when cold
Old Sep 1, 2005 | 04:26 AM
turbo
OK my car was sitting about an hour last time. I will do it sooner this time.
Old Sep 1, 2005 | 04:51 AM
njmaxseltd's Avatar
Fix the vehicle speed sensor issue, clear the error codes and see if the KS code comes back after that. If so, just replace it.
Your engine doesn't require 94 octane, your wasting your $$ using it.
Old Sep 1, 2005 | 01:04 PM
turbo
I found the car felt much better (faster) when using the 94. I have heard the same conclusions as well. (Shrugs shoulders)
homeofbacon
Sep 23, 2015 07:17 PM
JoshG
51
Sep 21, 2015 10:41 PM
ac max 92
Sep 17, 2015 07:35 AM
