will a 96 ecm work in a 95 ?
Old Sep 2, 2005 | 10:42 AM
THEJEFFERATOR's Avatar
i just got a ecm from a junked 96 a/t really cheap. there's a tsb about ecms in maxes built before jan 95 needing an upgraded/ revised ecm. my build date is 4/04. it still has the og unit. since i got this one cheap, i thought id try it, to see if it fixes the problems im having, but i dont want to fry anything !!!!
midway lists a 95 ecm and a 96-97, so obviosly there is a diff. but if it's just a matter of accessories or slight changes, i'd try it to rule out the ecm being bad.
anybody know what differences there might be?....thanx
Old Sep 2, 2005 | 11:16 AM
greengrass215's Avatar
your 95 max is OBD 1 and 96 and up are OBD 2.
Old Sep 2, 2005 | 11:22 AM
Jime's Avatar
Thats not true. Mine was built in 03/94 and its OBDII.
No one has ever reported having an OBDI 95
Old Sep 2, 2005 | 11:37 AM
my dad max is 95, its a obd 1 and my max is 96 obd 2. hey i might be wrong tho.
Old Sep 2, 2005 | 12:54 PM
mine is obd 2...any other diff.? sensors, or other powertrain controls?
Old Sep 2, 2005 | 01:45 PM
Jime's Avatar
I had a 97 and still have the 95 and from all the work I did on them, there weren't any differences that I noticed and I did a lot of mods to both. I have the FSM's for both if you want them so you can compare all the sensors. PM me.
Is that conclusive no, but its the best I can tell you.
Old Sep 2, 2005 | 01:51 PM
thanx. if it would do any damage, i hope they changed the plug so it wont plug in to my harness. im thinkin it will work, just bein cautious
Old Sep 2, 2005 | 06:02 PM
Mishmosh's Avatar
All model year 1995 Maxima's are OBDII. The scan connector is located in the passenger side foot well.
1996 ECU's should work fine in 1995.
Old Sep 2, 2005 | 10:20 PM
i30ds's Avatar
Armed and Dangerous
I thought the evap was different between 95 and 96... might trip some codes for that.
Old Sep 6, 2005 | 11:35 AM
Plugged in and ran, but got 7 codes for the evap. system
didn't run any better.....
f/s 96-97 automatic ecm..... or trade for 95 maf
Old Sep 6, 2005 | 11:51 AM
Nealoc187's Avatar
SLOW
There are NO OBDI 4th gen Maximas. Period. They are all OBDII.
To answer the original question, yes it will work.
Old Sep 6, 2005 | 12:30 PM
it will run, but 7 non-erasable codes for evap syst.
there is definatly a difference !!!
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
iflexsteel
Sep 2, 2015 08:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
