Slipping clutch?
Old Sep 4, 2005 | 11:21 AM
Maxi98se's Avatar
Slipping clutch?
Today while driving i noticed something funny. 1st and 2nd gear are good and strong when i shift into 3rd and floor it the rpm go up drop then it goes... kinda hesitating like it wants to go but its thinking about lol... is this a sign for a slipping clutch?? Tia
Old Sep 4, 2005 | 03:59 PM
Maxi98se's Avatar
anybody???? i changed my fuel filter today didnt help much, gonna try to change the spark plugs tommorow and see what happens...
Old Sep 4, 2005 | 04:03 PM
madmaxima420's Avatar
run for codes, check air,fuel filters,clean throttel body, and so on
Old Sep 4, 2005 | 04:05 PM
Maxi98se's Avatar
can i check codes if i dont have a check engine light on???
Old Sep 4, 2005 | 04:11 PM
THT's Avatar
THT
Throbbing member
Sure can. Read the stickies for how.
Old Sep 4, 2005 | 07:45 PM
Maxi98se's Avatar
anyone else want to share their similar experiences or just simply give me some input on this??? Ive already done the following: cleaned tb, changed fuel filter added fuel injector cleaner, and am going to replace the spark plugs tommorow to see if it helps any... otherwise im stumped...??? Tia
Old Sep 4, 2005 | 07:50 PM
MDeezy's Avatar
my slipping causes vibrations and fast drop in rpms, usually happens in the morning after the tranny has had all night to leak some gear juices onto the clutch.
Old Sep 4, 2005 | 08:48 PM
Maxi98se's Avatar
Im really wondering if this is a sign of a slipping clutch i will try to post a video up tommorow... 1st gear is great as well as 2nd i dont know what the problem can be??? I can start of in 4th gear as a friend suggested to see if the clutch is bad... When im in lets say 3rd, 4th or 5th gear and put the gas pedal to the floor the rpm goes up then drops like 500rpm quickly then goes back up before the max begins to move.....
Old Sep 5, 2005 | 05:05 AM
BigLou93SE's Avatar
Yes, it is.
10 char.
Old Sep 5, 2005 | 06:04 AM
Maxi98se's Avatar
Dayyumm... where can i get the clutch replaced in CT for a good price???
Old Sep 5, 2005 | 06:08 AM
maxgtr2000's Avatar
KH3 by popular demand
If you got any maxima meet buddies you could just do it yourself with help. But if no one has mechanical skills then prepare to spend about $400.
Old Sep 11, 2005 | 10:51 AM
boostaddict's Avatar
Fairly easy to DIY if you are half of a mechanic.
Old Sep 11, 2005 | 11:43 AM
nismos14's Avatar
§è~® f®ÈÄk
400 just for labor. Clutch is usually around 700 - 800 with parts.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
