Got 0403, 0304 and 0201 need opinions....
Hey guys, I have won a jackpot today. Have been standind at the traffic light and then CEL pops out with the drop of RPMs. Cheched the ECU and it came out 0304, 0403 and 0201. Just want to ask if anyone can give me approximate rate of the cost of repair. I have a warranty(4 star GE Warranty) but I am not sure if it will cover that. And if it is OK to drive for a few days with this codes. Thanks!!!
I wouldn't necessarily say 0304 Knock Sensor code will have you using more gas. My car throws that code at me and I still get about 25 mpg around town and 28 on longer trips. I've seen this damn knock sensor thing debated here since I've been here and my conclusion is that the majority of maximas have the code and it doesn't always mean it is bad. I'd say fix the other two things before you spend $200+ on having a shop change that particular sensor.
Just my two cents from my experiences...Good Luck
Jettech
Jettech
Originally Posted by s0ber
you might wanna tell us what 0403 and 0201 is, im too lazy to go figure it out...
also 0201 i think is ignition circuit fault or something correct? Sound's like a coilpack
plus I'm on dial up now so I'm even lazier on looking it up.
check your tps, its explained in the howtos somewhere, its probably out of wack, adjust it to proper reading... reset, wait for codes to come back, you probably have a bad coilpack somewhere also, could be a few things tho
blakkrob
Oct 10, 2002 07:47 PM
TurDz
Aug 27, 2001 06:30 PM
JeepRage
Jun 24, 2001 05:25 PM
