SES light on after engine repair
Old Sep 6, 2005 | 07:18 PM
chamiz's Avatar
I just repair the engine by doing a cylinder head and gasket change, along with cooling system. I had no light until I drove for about 30 minutes. Went to the mechanics and said the computer is reprogramming itself and will take a couple of days. Is this true?
Old Sep 6, 2005 | 07:26 PM
njmodi's Avatar
Do I get a tax break?
Did you just do all that work yourself? If yes, then it surprises me that you are asking such a rudimentary question about the SES.
In any case, your mechanic needs a .
Read the ECU howto sticky and retrieve all the stored codes in the ECU, that will help you figure out what troubles the ECU is reporting. Alternatively, go to Autozone, where they will retrieve the codes for you for free.
Out of curiosity, why did you need to replace the head gasket?
Cheers.
Old Sep 6, 2005 | 07:58 PM
i30ds's Avatar
Armed and Dangerous
I like to know too... "doing a cylinder head and gasket change" makes me think that the entire head and head gasket were replaced... which is unusual.
Old Sep 7, 2005 | 06:06 AM
chamiz's Avatar
No, I did not do it all by myself. My mechanic did it. And yes, it was the entire cylinder head in the rear along with head gasket being replaced. I thought I seen posts that said the computer codes that trigger the SES light will be re-programmed somewhere from a day to a couple of days when the engine is disconnected for 3 weeks. Just want to confirm.
Old Sep 7, 2005 | 06:43 AM
njmodi's Avatar
If you read the stickies at the top of the 4th Gen Forum, you'll find instructions on how to retrieve the error codes stored in the computer. That is why the light is set. It will not fix itself.
I'm not sure what to think of a mechanic that can replaces heads, but not retrieve ECU codes via an OBD-II scanner...
Old Sep 7, 2005 | 07:03 AM
chamiz's Avatar
He did retrieve the ECU codes, but he said that it will re-program itself since it has been disconnected for weeks. It was giving codes one by one, and then clearing some of it one by one, but not all yet. Just seeing if anyone experience this before. I read from some inspection posts saying that it 'does' go away in a couple of days. If no one experiences this, I have to go to find out the problem. Thanks for replying.
Old Sep 7, 2005 | 07:04 AM
njmodi's Avatar
Did he tell you which codes he found?
Like I said, the ECU has dectected faults, which more than likely will NOT fix themselves.
Old Sep 7, 2005 | 07:09 AM
NmexMAX's Avatar
dot dot dot ...
Check your codes.
Check your codes.
You never answered the question, why did you need to replace the head?
Check your codes.
Check your codes.
Your theory on 4th gen ECU/diagnostic/reset/ etc is pretty skewed ... If something is wrong, the light will trip, even if not lit, there may be codes stored, check them very soon to see codes are stored.
Check your codes.
Check your codes.
It wont go away, only to return, you have to fix the problem in order for it to go away.
Did I mention you should check your codes?
Old Sep 7, 2005 | 07:24 AM
Loe max's Avatar
Originally Posted by NmexMAX
Check your codes.
Check your codes.
Check your codes.
Check your codes.
Check your codes.
Check your codes.
Im not seeing the hidden message in your post
Old Sep 7, 2005 | 07:25 AM
chamiz's Avatar
Will check it later. I replace the head because it there was a hole inside.
Old Sep 7, 2005 | 07:37 AM
NmexMAX's Avatar
dot dot dot ...
You're a bit vague in your posts ..My point is, you need to help us help you.
Provide details of the vehicles history .. one important note.. why is there a hole in your head?
This may or may not have vital information that may help better diagnose your problem... Did your mechanic tell you it had a hole or did you see it?
FYI .. My heads have A LOT of holes in them
Old Sep 7, 2005 | 01:01 PM
chamiz's Avatar
Sorry for the vague posts. Okay, let me start off with the history:
This Maxima had a lot of problem initially. First off, it was burning oil badly, about 2 quarts per 500 miles. There was like huge blue smoke from the exhaust everytime I accelerate. So I ask to fix that problem. He bought a set of gaskets and screws and took off the 2 valve covers on the engine. He also gave it a coolant flush along with new hoses and radiator cap. He discovered another problem and asked me if I want to fix it. So I bought the used cylinder head and he installed it for me. Now everything was fine after 3 weeks. No more burning oil. I even test drove with him for 45 minutes. The next day, I tried driving it again, in about 5 minutes in a turn, the SES light came up. So I went to him and he put in the OBD-II scanner to check for codes, it came up with 3 codes, and then 2, then 1, then none after the turning the engine on. He told me that if it happens again, it should clear away in a couple of days. And I remember a couple of people on Maxima.org had their SES light cleared away after an installation of 'something'.
Good things that happened:
Feel an increase in HP when acceleration
No more burning engine oil
Bad things that happened:
SES light
White smoke once in the first 500 miles (burning coolant?)
So I checked the coolant, was at the MIN line.
Nothing else that I am worried about. Inspection is in another month, that's why I posed the question. Guess now I have to fix these problem first.
Thanks for reading.
Old Sep 7, 2005 | 01:03 PM
njmodi's Avatar
White smoke and low coolant indicates you are burning coolant ... which means your head gasket is leaking, which means you are going to warp the head, which means... you get the idea... or no?
Old Sep 7, 2005 | 01:04 PM
NmexMAX's Avatar
dot dot dot ...
I would;ve just got a new engine for that hassle and price.
are the codes?
Old Sep 7, 2005 | 03:17 PM
njmaxseltd's Avatar
That process you describe doesn't happen.
The codes remain there until you delete them or the ECU see's your enigne run correctly from a cold start up to full hot several (50?) times.
They don't dissapear as you read them and run the enigne.
If I were you, I'd be looking for another mechanic to work on the car.
chamiz's Avatar
I would agree on the new engine. Wasted all my time and money. I go chech the codes on Friday.
Old Sep 7, 2005 | 03:18 PM
chamiz's Avatar
The head gasket problem again? Someone quote me a price.
Old Sep 7, 2005 | 03:58 PM
NmexMAX's Avatar
dot dot dot ...
If you have your car there with you, and have 15 extra minutes with a flat screwdriver, check the codes .. now..
Old Sep 7, 2005 | 04:17 PM
njmaxseltd's Avatar
1234567890......
Old Sep 7, 2005 | 04:52 PM
njmodi's Avatar
Look closely at the pic if you don't get it....
Old Sep 7, 2005 | 05:16 PM
i30ds's Avatar
Armed and Dangerous
He discovered another problem and asked me if I want to fix it. So I bought the used cylinder head and he installed it for me...
THis still does not describe the "hole" in the head problem.
Old Sep 7, 2005 | 05:39 PM
chamiz's Avatar
Used car. Will get the codes later this week.
Old Sep 7, 2005 | 11:06 PM
Fr33way™'s Avatar
Wild for Width
Pull The Codes
If you are having those kind of problems on a '99 it must have been BEAT before you bought it. It takes 5 mins to check the codes. Do it now or just keep paying this idiot to tell you that the light does magical blinks and resets itself.
PULL YOUR CODES
and go somewhere else to get the work done . . .
Old Sep 12, 2005 | 07:19 AM
chamiz's Avatar
Finally Codes!
Here's the codes from the scanner:
P0403 - EGR Valve Fault
P0161 - O2 Sensor (2nd bank)
Old Sep 12, 2005 | 07:32 AM
NmexMAX's Avatar
dot dot dot ...
Neither of those have anything to do with your head problem ...
Old Sep 12, 2005 | 07:40 AM
MDeezy's Avatar
This thread is hilarious
The mechanic has screwed you, and if your still having most of the same problems, I would look into finding another engine and see if some people around you can help with the install for a decent price.
Old Sep 12, 2005 | 03:22 PM
chamiz's Avatar
I'm not talking about the head problem here. It's only about the CEL after the repairs. This mechanic doesn't seem to fix most of my problems. Changing to another mechanic. Wasted enough money for a new engine. Thanks all.
Old Sep 12, 2005 | 09:14 PM
DcMaN's Avatar
man how much did you pay for your mechanic to install this ? How many miles on your engine ? I had a leak in the timing cover got a engine with 40k on it from a junkyard. I paid 350$ for the engineSwapped it in everything solved not one problem! Not even a cel. Even the coil packs they gave me were good!
Old Sep 12, 2005 | 10:33 PM
chamiz's Avatar
I paid about $1500 total. How much were yours including the labor for swap?
Old Sep 13, 2005 | 06:51 AM
NmexMAX's Avatar
dot dot dot ...
You could've had a 3.5L swap for tha price
Old Sep 13, 2005 | 06:58 AM
MDeezy's Avatar
not including headers and clutch
Old Sep 13, 2005 | 07:08 AM
NmexMAX's Avatar
dot dot dot ...
Depends on how hard he looked maybe
... But why not keep the boat anchor manifolds and stock clutch or leave it auto ... Until the $$ came in?
Old Sep 15, 2005 | 04:36 PM
DcMaN's Avatar
i paid 1500$ including the engine :]
vingodine
45
May 21, 2016 12:46 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
yat70458
Aug 3, 2015 01:16 PM
maxima297
Aug 3, 2015 12:50 PM
