High RPM's when in neutral???
Old Sep 10, 2005 | 01:34 PM
ja1997max's Avatar
When I shift into neutral from any gear sometimes my rev's just start to climb to anywhere between 1500 - 2000 RPMs. It stay's there until I blip the throttle and then the RPMs settle down lower. This also occurs occasionally when I just start my car.
What is the normal rpms the car should be at in neutral?? How can I fix this problem (TB cleaning???). Thanks in advance for any replies.
Jordan
Old Sep 10, 2005 | 04:34 PM
bhmax16's Avatar
If it's cold your idle will be higher. Mine is around 1200-1500 in the morning when it's like 50 degrees outside. Once the car warms up it is 600-700 (where it should be). I recently took out my IACV and cleaned it though then readjusted my idle afterwards. You should try that before worrying about anything else IMO
Unclejunebug
Apr 2, 2016 05:42 AM
maxinout93
Oct 31, 2015 02:04 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
