TRANSMISSION (locking or non-locking)
Old Sep 10, 2005 | 05:48 PM
AGRECORDS
how to you know which tranny you have in an auto or manual.
isnt there a number somewhere in your engine bay?
whats the difference in locking and non-locking?
Old Sep 10, 2005 | 06:02 PM
MDeezy's Avatar
I was told but forget, the information was somehow related to the information on door jam. Non-Locking is Open Diff . . . more than likely thats the tranny you would want. I honnestly dont know if any maxs cant with a locking diff.
Old Sep 10, 2005 | 06:12 PM
AGRECORDS
well if anyone know this info it would help me a bunch. im going for major power soon so i need a fresh tranny but need to know this info first!
Old Sep 10, 2005 | 06:15 PM
MDeezy's Avatar
For Major Power you would want a VLSD tranny above all, if not an Open Diff tranny to help somewhat balance power down, not as good as a VLSD would but better than a locking diff would.
But if anyone knew I'm sure they'll chime in soon
Old Sep 10, 2005 | 07:05 PM
grey99max's Avatar
LandShark has Cosworth
For automatics:
It's on the plate in the engine compartment, on the firewall on the passenger side. Open the hood, look back and to the left, and it's a shiny plate with rows of numbers.
One of the rows will say either
RE4F04A - open differential - One tire can easily spin by itself - bad
RE4F04V - VLSD differential - Both tires will pull together - good
These are the only two types of differentials factory-made for our cars. No lockers.
The number is also on the transmission, I believe. I think the manuals use the same "A" and "V" codes. Seems that the USA did not get the good stuff on a regular basis - most went to Canada on this continent, and Infiniti I30s have a lot of VLSD transmissions as well.
Lucky Canadians.
Old Sep 10, 2005 | 07:13 PM
MDeezy's Avatar
I knew I thought I saw it somewhere. . . faqs.
Old Sep 10, 2005 | 07:28 PM
AGRECORDS
what about this 97 maxima non-locking diff - AOD (SSS) WHAT DOSE THAT MEAN?
i found it on used car-parts.com for 330$ 71,000 on it
Old Sep 10, 2005 | 08:01 PM
JClaw's Avatar
Jack your car up. Turn one wheel. If the other wheel doesn't turn or turns a little it's an open diff. If both wheels turn at the same time it's a VLSD. If the other wheel turns in the opposite direction of the one you are turning, it's a VLSD that doesn't work anymore (like mine), and fonctions like an open diff.
Old Sep 10, 2005 | 09:26 PM
i30ds's Avatar
Armed and Dangerous
Originally Posted by JClaw
...If the other wheel turns in the opposite direction of the one you are turning, it's a VLSD that doesn't work anymore (like mine), and fonctions like an open diff.
Yeah, bad viscous coupling.
Old Sep 10, 2005 | 09:40 PM
aussie983's Avatar
Did any 4th gen auto Nissans, as opposed to infinitis ever come with VLSD?
user 11122324
42
Jul 18, 2022 03:35 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Pied
Sep 26, 2015 03:29 PM
