3.5 05 intake on a 95 Will it work?
Old Sep 10, 2005 | 06:50 PM
deoncollins69
I am looking into doing a swap and was wondering if it is worth it. First off is the 04-05 Intake a VI intake? I know ihave heard the 3.5 can be stufed into the older Maxima's if you use the 95-99 intake and do some adapters for the cam gears but can you put a 04-05 intake on a 95-99 3.0? If it would gain me some ponies and soem Fuel milage I may just do it. Chime in if you have done this swap. I have a partial 00vi setup but would go with the 04-05 if it is worth it.
Old Sep 10, 2005 | 07:01 PM
WielkiWaac's Avatar
MaximaDriver
is 02-03 intake same like 04 05??
Old Sep 10, 2005 | 07:03 PM
deoncollins69
I do not know. I have read up on the Mevi swap and the 00vi swap but have seen very little on a 02-03 3.5 swap for an intake.
Old Sep 10, 2005 | 07:10 PM
WielkiWaac's Avatar
MaximaDriver
i didnt see anythink about swapping 04 intake
Old Sep 10, 2005 | 07:27 PM
MaxGordon7's Avatar
its all about the upper manifold on 00-01 you want
Old Sep 10, 2005 | 07:40 PM
deoncollins69
So the 04-05 intakes are just a normal every day intake then nothing special about them.
Old Sep 10, 2005 | 07:45 PM
Tatanko's Avatar
Bacon Lover
I was pretty sure all VQ35 engines had a variable intake manifold. Either way, you wouldn't gain anything from attempting to use one over an 00VI, and you'd need the 3.5 heads in order to use it anyway, making it all the more of a headache for not much benefit.
Old Sep 10, 2005 | 07:58 PM
JClaw's Avatar
3.5 IM is nothing special, it's a bit better than the regular 3.0 4th gen USIM, peak power is about 5600 and it drops off hard after 6200-6300 or so, while the 4th gen drop off is more around 6000, but the one you want is the 00 VI. It peaks around 6400 and doesn't really drop off until 7k. The "special" IM for the 3.5 is the 350z intake, which has an amazingly flat tq and power curve, but it doesn't fit FWD applications, unfortunately (can't close the hood).
Old Sep 10, 2005 | 08:08 PM
WielkiWaac's Avatar
MaximaDriver
so you saying that better si 00VI than "04VI"
Old Sep 10, 2005 | 08:19 PM
deoncollins69
I'm a bit confused on why you would have to use the 3.5 heads. I can stuff a 3.5 into a 95-99 by using the intake from the 3.0 and all the rest ofthe parts with it. There fore a 3.5 intake should fit the 3.0 with no major problems right? I guess there might be clearance problem or 2 but a grinder and tig welder can fix that problem.
Old Sep 10, 2005 | 08:21 PM
JClaw's Avatar
For a 3.0L the 00-01 VI is the best possible option. Great mid range power, super flat TQ and HP curves, and excellent flow all the way to 7000 rpms.
Old Sep 10, 2005 | 08:42 PM
Maxride99's Avatar
How difficult is the swap to the '00vi? is this something a weekend hobbyist can do? or is this serious engine labor?
Old Sep 10, 2005 | 08:47 PM
MaxGordon7's Avatar
easy for a weekend hobbyist, its not too bad.
Old Sep 10, 2005 | 08:48 PM
Tatanko's Avatar
Bacon Lover
The 3.5 intake manifold will not bolt up to the 3.0 heads. The heads are different. Also, it hasn't been "proven" per se, but certain people believe the 3.5 heads flow better. I'm not saying that's fact, merely what some people believe to be true.
Old Sep 11, 2005 | 09:20 AM
deoncollins69
So if a the 3.5 heads are different how can you bolt a 3.0 intake to the 3.5? I have seen 2 with the 3.5 in them using a stock 3.0 intake.
Old Sep 11, 2005 | 09:32 AM
Tatanko's Avatar
Bacon Lover
That's because they're using the 3.0 heads.
Old Sep 11, 2005 | 01:21 PM
deoncollins69
I'm am sure all they did was use the spacer to set the cam gears off to get the proper alignment up for the chain. I am im them both now to see if that is correct but I know that's what they both said.
Old Sep 11, 2005 | 02:45 PM
crazy97's Avatar
Why would anyone put a 3.0 intake on a 3.5 engine? Isn't that like buying too small of a condom?
Old Sep 11, 2005 | 04:49 PM
sonicrunch's Avatar
Intresting thead.
So just so I am crystal clear, The 3.5 intake is NOT a VI, correct?
I would guess not. You can't beat cubic inches. HA!
Old Sep 11, 2005 | 05:21 PM
deoncollins69
Why would anyone put a 3.5 in 95-99 Maxima? Because they can and it's a sleeper if you don't know about it.
Old Sep 11, 2005 | 07:02 PM
Tatanko's Avatar
Bacon Lover
Originally Posted by sonicrunch
Intresting thead.
You would guess wrong. It is indeed a VI.
No, they're using the 3.0 heads because the intake manifolds don't line up, IIRC.
Old Sep 11, 2005 | 07:51 PM
Maxride99's Avatar
this is a great thread, very informative
question: what else would you need other than the 00vi to do the 00vi swap? I imagine you will at least need a new gasket, anything else? anybody? thanks!
is it worth it to do this swap? sounds like it is better than stock 4th gen intake
Old Sep 11, 2005 | 08:01 PM
WielkiWaac's Avatar
MaximaDriver
you will find more info in all motor forum
Old Sep 11, 2005 | 09:40 PM
sonicrunch's Avatar
thanks for clarifying that for me.
Just out of curiosity, are there any good pics of the 3.5 IM on the org?
Old Sep 13, 2005 | 07:52 AM
NmexMAX's Avatar
dot dot dot ...
Yes there are ...
Old Sep 24, 2005 | 07:59 PM
deoncollins69
Any more comments on This?
Old Sep 24, 2005 | 08:04 PM
Tatanko's Avatar
Bacon Lover
What else is there to say?
Old Sep 24, 2005 | 09:39 PM
goldtooth's Avatar
owned.
now ---> of thread. lol jk
95Maxi
Aug 29, 2015 09:38 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
maxinout93
Aug 16, 2015 07:25 PM
kenc15
Aug 5, 2015 08:29 AM
