Filler Bolt on Tranny.
Old Sep 11, 2005 | 12:22 PM
MDeezy's Avatar
Was about to flush my tranny, I was trying to get the fill bolt off (still soaking in WD-40 right now). Upon closer inspection I noticed a teflon thread sealant like rubbery feeling thing around the bolt. Is this a reusable piece or when ever the drain bolt is taken off a new one of those things would need to be put on?
wish I had a camera for pics.
Old Sep 11, 2005 | 12:28 PM
2 Da Max's Avatar
they say you need all NEW 21 SCREWS!! i was like fawk that i used the same screws but used loc tight, you do need a new drain plug though..
oo wait the drain plug seal? you need a new drain plug if you take off the old one for sure
o btw if you are dropping the pan you definately need a new pan seal, and i think i paid like 23 dollars for a new seal and fliter screen at pepboys
Old Sep 11, 2005 | 01:00 PM
MDeezy's Avatar
I'm a 5 speed 2 da max, so it will be easy drain and refill and drive, I dont have to do none of that auto stuff.
On the 5 speed trannies there is a large about half dollar size filler bolt its a bronze-ish color and you just stick a half inch socket in their an unbolt. Mine is a biitch to take off and I noticed a light blue-ish glue look around aroud the threads at the base of the bolt.
I tried but its very tough, I'm going to wait till I get my impact wrench, better jack (using OEM) so I can get more height and clearance.
Was boared and figured I could drain and fill my trans so she'll feel smooth next week.
Old Sep 11, 2005 | 01:03 PM
Broaner's Avatar
2060lbs and falling...
No need for any teflon tape or anything on the tranny bolts. Just stick it back in.
Old Sep 11, 2005 | 01:55 PM
nismos14's Avatar
§è~® f®ÈÄk
No need to worry about getting any additional stuff. Drain, refill till it drips out, good to go.
Old Sep 11, 2005 | 04:12 PM
MDeezy's Avatar
Great thanks for that info. I just see some type of teflon or something already on their and was curious. Oddly enough in reading thru the 350z FSM, they used some type of teflon on the filler bolt.
Old Sep 11, 2005 | 04:35 PM
potownrob's Avatar
What gear oil should we be using in our manual trannies? Is it like other cars where you reach your finger in the hole and add some if you can't feel any oil in there ?
Old Sep 11, 2005 | 04:36 PM
nismos14's Avatar
§è~® f®ÈÄk
First time flushing the fluid?
Old Sep 11, 2005 | 04:38 PM
MDeezy's Avatar
We should be running GL4 only fluids in our trannies. Redline and Amsoil are great products that work and protect well.
If you have an auto check the dipstick for fluid level.
For Manual trannies you could if you want to stick you finger in, tranny should be full to the drain bolt with gear oil.
Old Sep 11, 2005 | 04:39 PM
potownrob's Avatar
I gather I should drain and replace rather than just make sure it's filled, especially since I have no idea if it's ever been changed in 72000 miles
Old Sep 11, 2005 | 04:40 PM
2 Da Max's Avatar
lol i forgot you were 5spd bro. what you mean oem height??
Old Sep 11, 2005 | 04:42 PM
potownrob's Avatar
Don't you mean full to the fill bolt? How much fluid do I need to have to fill it after draining?
Old Sep 11, 2005 | 04:43 PM
nismos14's Avatar
§è~® f®ÈÄk
He said he's using the oem jack to raise it up. He needs a floor jack or something else.
Old Sep 11, 2005 | 04:45 PM
MDeezy's Avatar
Oh yea 5 speed
Same thing, 4.5 quarts is needed.
Yea I meant I was using the OEM Jack that comes with the car so I didnt get the car that high off the ground, so I couldnt menouver a lot to try and get that bolt off, but I will leave it for the impact wrench to handle.
Old Sep 11, 2005 | 04:55 PM
2 Da Max's Avatar
i hate that Jack!! shiet takes me hours to use!!
Old Sep 11, 2005 | 04:59 PM
potownrob's Avatar
Found the how to for gear oil change :
http://vbxmaxima.8m.com/mtoil.html
Old Sep 11, 2005 | 05:28 PM
potownrob's Avatar
Has anyone found GL4 75W90 or 80W90 gear oil on amsoil's site? All I can find is GL5 in that weight
Old Sep 11, 2005 | 05:48 PM
MDeezy's Avatar
the fluid section has all this informations stickied for your convience. Redlines web site has the gl4 fluid you'll need for your tranny. amsoil maybe harder to find but not impossible.
Old Sep 11, 2005 | 09:13 PM
bhmax16's Avatar
I wouldn't recommend using an impact wrench on that bolt. If it happens to be really on there you don't want to risk breaking it and leaving part of it inside your tranny. If I were you I'd soak it with some pb blaster (at work we call it money **** ) then use a big breaker bar to get that sumbish loose. I didn't need a huge breaker bar for mine, only 18in
Old Sep 11, 2005 | 09:25 PM
potownrob's Avatar
Thanks. I found a link to it and ordered a bunch of amsoil quarts and a pump that hooks up to the bottles with a hose on it
Old Sep 12, 2005 | 05:00 AM
MDeezy's Avatar
Yea I was thinking a impact wrench maybe overkill but I am using an 18in break bar. Before I do the impact wrench I'll get some PB blaster (WD-40 just seems too wattery) and soak it with that, and maybe start the car and let the tranny get some heat to help soak the pb and loosen the bolt.
The dealership was the last to touch the tranny, and I'm pretty sure the bolted tha sucker on tight.
Old Sep 12, 2005 | 06:51 AM
4DRSpeed's Avatar
Project Ruby......
When I changed out my tranny fluid. I drained it and then went for the fill bolt. I couldn't get this thing to budge as was freaking out. So I grabbed the can of PB Blaster, soaked it let it set for 5 minutes went back under there with the breaker bar and after a real good tug the thing came loose.
Old Sep 12, 2005 | 06:59 AM
MDeezy's Avatar
then some PB blaster I will need. Your story right there is why I wanted to make sure I got the fill bolt off first, I would not want to be in the situation where I couldnt fill back u p the tranny with fluid.
Old Sep 12, 2005 | 07:07 AM
4DRSpeed's Avatar
Project Ruby......
Ya sometimes I need to think ahead, but don't.
I'm just happy I got the bolt off.
Old Sep 12, 2005 | 07:14 AM
MDeezy's Avatar
indeed, that must have been scary for few mintues. . .
Old Sep 12, 2005 | 11:50 AM
bhmax16's Avatar
If you have to stick a pipe on the end (cheater bar) of the 18in breaker bar for more leverage. Just don't use the impact whatever you do And yes pb blaster is your friend
Old Sep 12, 2005 | 12:59 PM
MDeezy's Avatar
I'll try some more leverage. my half inch break bar wouldnt seat in all the way so maybe that will help me get it off when the time comes.
Old Sep 12, 2005 | 01:22 PM
konak85's Avatar
IS it true that if you haven't changed your auto tranny fluid in a long time its better to just leave the old fluid in? Its weird but i heard it a few times.
litch
123
Jan 4, 2024 07:01 PM
05RLS2
Apr 14, 2016 11:49 AM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
