97-99 trunk on a 96 maxima?
Old Sep 11, 2005 | 03:46 PM
AGRECORDS
can i do this... what's all needed?
Old Sep 11, 2005 | 04:08 PM
Jason R's Avatar
aka UNCDooD
harnesses for the taillight bulbs, tail lights and a trunklid.
Old Sep 11, 2005 | 04:11 PM
86maxima96's Avatar
I Broke OT
oh, you will also need a 96 Maxima car.
Old Sep 11, 2005 | 04:19 PM
endy's Avatar
do you want to do this because of the red and clear tail lights? i believe custommaxima got some 95 96 clear tail lights.. why don't you just save the trouble and get it from there?
just a suggestion.. and good luck
Old Sep 11, 2005 | 04:53 PM
MDeezy's Avatar
They say you may need the bottom latch so that the trunk can close. . . I didnt manage to get the bottom latch but the hood closes fine and with no extra force at all. Only thing the trunk poper cant pop it open, I'm going to find a latch off a 97 so I can pop the trunk again.
Old Sep 11, 2005 | 05:20 PM
mansurxk's Avatar
you dont need the latch...i reused mine, works fine
Old Sep 11, 2005 | 05:49 PM
MDeezy's Avatar
really? you put on the 97 lid and everything works fine?
I'll try raising my latch see if that helps some, but everything is lined up perfectly.
Old Sep 11, 2005 | 05:59 PM
Maxride99's Avatar
could someone post a pic of the clear taillights? is this an easy conversion?
Old Sep 11, 2005 | 06:02 PM
MDeezy's Avatar
what clear tail lights
Old Sep 11, 2005 | 06:17 PM
AGRECORDS
i really want to get the led lights for the 97-99 but i have a 96 so...
Old Sep 11, 2005 | 06:20 PM
MDeezy's Avatar
I was in the same predicament, keep my eyes open get the lights and the lid. check the for sale section, and www.car-part.com
Old Sep 11, 2005 | 06:27 PM
AGRECORDS
did you get the leds?
Old Sep 11, 2005 | 06:33 PM
MDeezy's Avatar
Yes sir, GEN IIs They look sexy.
Old Sep 11, 2005 | 06:36 PM
AGRECORDS
dam hell so you had no problems with the 97 trunk install? what all did you need for the install?
Old Sep 11, 2005 | 06:38 PM
MDeezy's Avatar
a 97 trunk and thats it. Took about 30 mins to swap the lids and tails. No problems at all.
Old Sep 11, 2005 | 06:39 PM
AGRECORDS
so why are people saying you need the latch ?
Old Sep 11, 2005 | 06:45 PM
MDeezy's Avatar
some have said without it you wont be able to close the lid or lock it, maybe I was lucky.
Old Sep 11, 2005 | 07:00 PM
1HOTMAX's Avatar
i have a 97-99 trunk fs: $100
Old Sep 11, 2005 | 08:30 PM
Tyrexx's Avatar
You need is a 97-99 trunk and 97-99 taillights.
Old Sep 12, 2005 | 05:54 AM
BourneJ's Avatar
How about you read the FAQ & How To's first.......
http://forums.maxima.org/showthread....11#post2393811
Old Sep 12, 2005 | 10:40 AM
Jason R's Avatar
aka UNCDooD
already posted that. but he will need the taillight harnesses as well since the bulb sockets that screw into the back of the 97-99 tails are different.
Old Sep 13, 2005 | 09:49 AM
Tyrexx's Avatar
If you're talking about the harnesses that are 2 inches long and that are attached to the taillights you are correct. There's no reason to remove those so I just assume they are part of the actual taillights.
Old Sep 13, 2005 | 02:22 PM
AGRECORDS
ok so the 96 harness/lights wont fit the 97-99 tail lights? (twist into position)?
Old Sep 13, 2005 | 02:24 PM
Jason R's Avatar
aka UNCDooD
i'm talking about the part the bulbs plug into...the 95-96 plugs do not twist into the back of the tails like 97-99s do.
Old Sep 13, 2005 | 06:42 PM
MDeezy's Avatar
No they will not fit! You have to purchase the 97+ harnesses for it to work.
I learned this the hard way, since I had the GenIIs I had brake lights on my inner tails but had no reverse lights till I was able to atleast get my hands on one harness.
Btheman80
May 1, 2018 04:03 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
TMartinLVNV
Aug 16, 2015 01:48 PM
