CPS (ref) wire harness help.
Old Sep 12, 2005 | 03:13 PM
NmexMAX's Avatar
dot dot dot ...
Just recently I got a code (0407) and thought since I just replaced the sensor less than a year (20k) ago. So I go under and see what was going on there, and to my surprise I see that the harness to the CPS (ref) is mangled and chewed up by the acc.belt. It's only about 12" long and connects to the CPS, and has another larger connector on the other side behind the oil fitler.
So after searching for it online for a while, as it's only about a ft in length, but come to a conclusion that it's sold with the "main ECU harness".
Has anyone ever had similar experiences?
Old Sep 12, 2005 | 04:03 PM
njmodi's Avatar
Do I get a tax break?
OMG OMG OMG!!! NMex is actually ASKING a question instead of answering them!!
I just pulled and cleaned that CPS sensor two weekends ago... but I didn't look at the harness closely.
I just took a look in Nissan FAST briefly but couldn't identify that part of a harness as a seperate P/N.. I gotta run for now - but I can look again when I get back if you still need.
Old Sep 12, 2005 | 04:07 PM
NmexMAX's Avatar
dot dot dot ...
Yup, finally asking a ? nj, I would appreciate it if you could do that for me... This hard strating is pissing me off.
I searched and there's a similar thread, looks like a quick reference from the FSM wiring diagram and I should be good to go with a little self siwring job. Although I found a complete harness from www.car-part.com for ~ 80$, I can use what I need, but then I'll have an incomplete harness with no use for it. Then again, I could replace any other damaged areas I may find on my 10 y/o 230k beast ... so it's sort of a tough decision right now.
Old Sep 12, 2005 | 04:12 PM
njmodi's Avatar
The FAST software is really tedious to use until you get used to it and I'm not very good at it yet... I found the CPS schematic but no harnesses are shown there... I'll be online again in 2 hours or so.. I'll post back with what I'm able to dig up then (if you haven't already got the answer).
Do you have the FSM?
Old Sep 12, 2005 | 04:14 PM
NmexMAX's Avatar
dot dot dot ...
I don't, not for my 4g, only got my 03
Old Sep 12, 2005 | 04:25 PM
99Automagic
You can download one off of jime's site.
Old Sep 12, 2005 | 04:49 PM
MDeezy's Avatar
Dont know if I'm crazy but I cant dig up a schematic for the CPS in the FSM.
I'm still in shock Nmex is asking a question!
but in all seriousness what do you need help with Nmex? you need the wiring diagram of the CPS (Ref)?
Old Sep 12, 2005 | 04:52 PM
Loe max's Avatar
Yes, thats my only answer
Old Oct 24, 2005 | 12:15 PM
NmexMAX's Avatar
dot dot dot ...
.. Car starts as fast as my 2003 now ... Thanks to those who helped ...
Old Oct 24, 2005 | 12:17 PM
Loe max's Avatar
I knew my answer would help out
Old Oct 24, 2005 | 12:18 PM
njmodi's Avatar
I got your PM too...
Old Oct 24, 2005 | 12:20 PM
NmexMAX's Avatar
dot dot dot ...
Gotta love the old 's
doctorpullit
Mar 29, 2016 11:08 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
