Trans Vin Number
I don't have my 96 max here, it is with my daughter at college. However I do rembember on that particular model there is an ID tag some where under the hood that will give engine code and trans code. On the trans code near the end of one of the sequence of numbers will be a letter A or V. V stands for viscous or limited slip. I don't know what the A stands for. Take a look under the hood see if you have that ID then call the nissan dealer to verify what the trans code means.
ya there should be a tranny code stamped somewhere on the bellhousing, i think closer to the engine side. if it ends in a V it should be LSD, and if it's open diff it hink it ends in an A. just curious, how much did u pay for this tranny?
Originally Posted by madmaxima420
i payed 1200 for the tranny and got a 95 motor for 350 55k on both
<tap tap> Is this thing on <tap tap>
Check the pictures above, compare it with your transmisison
The A in the transmission code means it the open trans type, won't help you as the transmission is out of the car so no VIN plate.
I looked on my trans and I can't see any model numbers (trans is on my garage floor so I have had a good look)
Originally Posted by killerVQ30DE
Are you just trying to brag or do you want to know if its LSD?
Originally Posted by MaximaSE96
i am gonna be a **** today but its impossible for the tranny to have a VIN...it can have a TIN but not a VIN
VIN plate is bolted to your firewall.. as well as having the VIN code for the car it also has the transmisison code on it
i havent got a chance to look a the trans itself, because im not at my house for the time being, but i did write down what was on the small plate on the trans.
JN1CA31A9 and *T303*23
and there are two upsidedown T's where the *'s are
and im not braging im just proud
jmlee44
Oct 2, 2022 02:13 PM
ef9
Oct 4, 2015 08:43 AM
