Interior Light Problem
Old Sep 14, 2005 | 08:26 PM
LiGhtSoUt's Avatar
okay heres my situation my interior door lights havnt been working for the longest amout of time now. Went to sears checked my battery and alternator noticed i have a short somewhere in the car. Now i still dont have any interior door lights and my odometer light blinks dims and then shuts off at points and the same with my stock Am/Fm stero unit this also happens when i put on the map lights also anyone have any suggestions on how to go about fixing this ??
Old Sep 14, 2005 | 09:04 PM
bhmax16's Avatar
Are you saying your maplight goes on but your other interior lights don't? If so it's a short somewhere. If the maplight doesn't work either then it's likely a fuse. Have you even checked your fuses? You should have done that before doing a battery and altenator check.
Old Sep 14, 2005 | 09:14 PM
Dman832's Avatar
My courtesy door light went out because I shorted something once...I took it to a mechanic and they gave it back to me with the other door light out, and part of the dash not lighting up anymore, and told me it was the BCM...I changed the BCM and no difference whatsoever, so they basically messed up my car and told me it was because of the aftermarket bulbs in there...which is ridiculous...and of course, it wasn't a blown fuse. I assume I caused a short somewhere. For your problem, the BCM coud be it, but it could a wire in between too. Don't know how you would've shorted it though...I just rewired the door lights with their own power (and fuse) and grounded through the door switch. I guess all I can say is if they tell you you need a BCM, get one from a junk yard and put it in yourself...
Old Sep 14, 2005 | 10:05 PM
LiGhtSoUt's Avatar
ive checked my fuses there not the problem lights do infact comeon butthey dim out and even get too the point where they turn off completly i know theres a short somewhere but iduno where to even begin to fix this problem
Old Sep 14, 2005 | 10:23 PM
Dman832's Avatar
so are you saying that the problem has gotten worse over time? like, it started with the door lights, then other stuff started acting up more and more frequently?
Old Sep 15, 2005 | 10:42 AM
LiGhtSoUt's Avatar
thats exactly wat im saying it started out with the door lights now recently maybe like 2-3 weeks the gauge cluster and am/fm radio light have been acting up. So i dont want it getting anyworse so im trying to resolve the problem. Fuses are fine because if it was a fuse then the lights wouldnt have turned on in the first place and yes i did check the fuses anyone have any words of advice
Old Sep 15, 2005 | 02:17 PM
jkslaughter@hot's Avatar
Be sure to check the grounds including the one coming off the illumination control switch
Old Sep 16, 2005 | 07:36 AM
LiGhtSoUt's Avatar
will do that today
homeyclaus
Sep 3, 2015 06:15 PM
rbaker100
Aug 28, 2015 08:11 PM
Jeffesernia11
Aug 23, 2015 06:09 PM
Samedi
Aug 13, 2015 04:05 PM
yat70458
Aug 3, 2015 01:16 PM
