How Many Miles On Your MAX?
Old Apr 24, 2009 | 03:18 PM
  #241
bigorangexj's Avatar
i have 182k on my '96 and still going strong. hauling a 800 lb boat and trailer combo every week.
Old Apr 26, 2009 | 10:32 AM
  #242
95maximase's Avatar
I used to win this one all the time. 1995 Maxima SE. Original Motor. 274,xxx miles. Still got one on you though......I've been a member of the .org longer than you.....
Originally Posted by SQMaxima
I have been wondering how my Max conpairs to others on here so i figured I would start this thread....for fun!
OK, post how many miles you have and state weather your motor is original or not.
My Max has 285,000+ miles, original motor.
Still looking like I have the highest milage Max so far......not sure that is something to brag about.
Old Apr 26, 2009 | 02:15 PM
  #243
Product_Of_Korea's Avatar
well my first max went to 160k but i retired it.
The one that i own now has 185k and im shifting at 7300k
Old May 8, 2009 | 02:00 AM
  #244
slapys's Avatar
Hey guys, new here. Just joined because I bought a used 1999 SE off of Craigslist from a private party (person). Felt it was appropriate to ask a certain question in this thread.
So I discovered that my odometer had been rolled back about 100,000 miles. Odo says 75K, but I found an oil change sticker dated 2007 that says 144K. I would imagine this car has ~175K on the engine now. I felt angry/stupid when I figured this out, but I need to figure out what to do now.
So what do I do now? If I were to just keep the car, how long do you think it would run before it would get too expensive to continue to maintain? Could I get 3-4 years out of the car without replacing anything major (engine, transmission)? Any thoughts from the mechanically inclined on here?
I'll be checking this thread every day for the next month or so. Please let me know.
Old May 8, 2009 | 08:32 AM
  #245
lil1's Avatar
167k
Old May 13, 2009 | 01:18 AM
  #246
kitticat295's Avatar
only 86k =]
Old May 13, 2009 | 10:07 AM
  #247
LushMoney's Avatar
almost 149K. had since 74K.
only ever replaced alternator, starter, and knock sensor. everything else is tip top.
Old May 13, 2009 | 09:17 PM
  #248
REDLION81's Avatar
150k original motor, bought my max back in 2002 w/ 70k. No major problems, only had to replace battery and radiator once. Luv my maxima!
Old May 13, 2009 | 11:08 PM
  #249
trand71's Avatar
1999 SEL with 145k, had for over 4 years now, bought it with 80k. So far i have replaced the CV boots, tune up, one bent rim, 4 tires (Kuhmo Ecsta 245/45/17) - worn down to the wear bars, windshield, new brakes and rotors, and 2 alignments, front end accident - replaced the grill, hood, headlights, and bumper. Orginal motor....still lovin' her.
Old May 14, 2009 | 07:56 PM
  #250
anovib's Avatar
Well in my case a lot of stuff started wearing out at that exact mileage....but if you keep on repairing things as they go wrong then you'll definatly get 3 years at least. At that mileage i have replaced both front wheel bearings, both cv axles, both lower control arms, both tie rod ends, need new struts but i'll wait a while...If you do the work yourself you will save a ton and it is still cheaper than buying a new car.
Keep an ear out for weird noises and fix them before they get to problamatic or else a bunch of repairs will hit you at once.
Old May 14, 2009 | 10:24 PM
  #251
maxima92se's Avatar
201 586K miles, second motor because of the 00VI lol. Now new motor is boosted lets see long she hold on to dear life
Old May 14, 2009 | 10:55 PM
  #252
MAXiPAD72O's Avatar
ummm too many lol about 202 ona 97
Old May 14, 2009 | 11:27 PM
  #253
Xfactor22's Avatar
99 maxima
128k
Old May 15, 2009 | 11:29 AM
  #254
maxed_out_99's Avatar
how bout this
My max has 185, somtin thousand miles it runs fantastic i think my injectors are starting to go i bought it with 177k and an automatic trans these things really run FOREVER!
Old May 15, 2009 | 11:32 AM
  #255
change your fluids check for leaks or blow by if all checks out fine HAMMER DOWN!!!
Old May 15, 2009 | 11:50 AM
  #256
blower motor resistor (96maxgxe) that would make you blower motor only work on high
Old May 15, 2009 | 02:24 PM
  #257
dibquib's Avatar
284,000kms (180K miles?)
Bought with 120K on her. Just replaced original clutch.
LIkely needs tie rods, control arms, sway bar links etc as the front is a little loose but rides awful nice for all original parts!!
Old May 15, 2009 | 02:29 PM
  #258
96nismomaxi's Avatar
.org window licker
lets see my 95 had 274k when i swapped it for a 3.5 and sold it with 34k on the motor
than my 97 that i had for a month had 112k when sold and was stupid strong
and now my 99 has 174k and is gettin a little weak i think that it is time for a big swap!!!
Old May 16, 2009 | 01:53 PM
  #259
OC_Nooby's Avatar
155,448 and running strong
Old May 16, 2009 | 02:20 PM
  #260
i30_4life's Avatar
Just bought one with 108,000 1995
Old Jun 13, 2009 | 04:04 AM
  #261
TOMSNISMO66's Avatar
326,5XX Original Motor Trannys Got 59 K on it
Old Jun 13, 2009 | 05:16 AM
  #262
Shift_Nismo's Avatar
158,000, and pulling strong
Old Jun 13, 2009 | 06:34 AM
  #263
erty67's Avatar
Decal Specialist
130k
Old Jun 13, 2009 | 07:49 AM
  #264
fresh207's Avatar
98 172???
Old Jun 13, 2009 | 08:06 AM
  #265
Mistertones's Avatar
1996 Maxima SE 141,xxx. Original motor, tranny. Just replaced exhaust, and brakes since i've had it 2 months ago.
Old Jun 13, 2009 | 11:43 AM
  #266
4th4Lyfe's Avatar
1999 SE with 102k.
Old Jun 13, 2009 | 02:06 PM
  #267
matrix11229's Avatar
1997 GLE Auto, Original motor & transmission, 200,600 miles.
I got it with 189k three years ago and did the following:
Replaced: Alternator, starter, O2 & knock sensors,all suspension (struts, springs, control arms, tie rods, end links, etc), Egr canister in the back+control valve.
Need to replace radiator support , and some body work on passenger side.
Old Jun 13, 2009 | 02:49 PM
  #268
NineOhSE's Avatar
Around 130k on the original motor. I bought it almost exactly 2 years ago with 83.5k
Old Jun 13, 2009 | 06:25 PM
  #269
marklevinson1's Avatar
I bought my 97 maxima 5 years ago at 21,000 for $7,000. It has 93,000 on it now and I have never had one problem with it!
Old Jun 13, 2009 | 08:04 PM
  #270
dx_man's Avatar
97 max, registers (stuck) at 122K, but i think based on carfax report it is 200K +, maybe a guage swap already, odometer is declared exempt. Oh well, my mechanic fixed one leak (valve cover gasket) and says she is solid. Running like a champ.
Old Jun 13, 2009 | 10:15 PM
  #271
20" Max's Avatar
97 Max with 222k on the dash and still going strong.
Old Jun 14, 2009 | 01:07 AM
  #272
beehoon23's Avatar
202,224....Runs like a champ!
Old Jun 14, 2009 | 05:48 AM
  #273
loxety's Avatar
Like anovib said just keep up with the repairs and maintenance and you'll be ok. These cars are very well built.
Old Jun 14, 2009 | 11:56 AM
  #274
ColombianMax's Avatar
1995 GXE-5 312,500 miles original engine and transmission. Trans is starting to click and whine whether clutch is pressed in or not but its still driving excellent for the mileage. Will be rebuilding trans soon
Old Jun 14, 2009 | 07:39 PM
  #275
96WhiteMaxima's Avatar
1996 Nissan Maxima, 91, XXX miles, all original.
I'm a lucky bastard, I picked it up for 2 grand =]
Old Jun 14, 2009 | 07:59 PM
  #276
Ignorantkid's Avatar
Originally Posted by theshawn
41k ........
Daamn dude congrats on that one i wish my car had 41k shhhit my car just hit 119k original motor
Old Jun 14, 2009 | 09:11 PM
  #277
HandsonMaxima.'s Avatar
just hit 191xxx on my way up from flordia!
Old Jun 15, 2009 | 04:01 PM
  #278
bigtex144's Avatar
347,xxx... 347,064 to be exact... one week from today will be the two year anniversary of purchasing it at 307K. Since then, all I've had to replace are 2 o2 sensors (the norm), replace the original rear struts, a $30 used tire (Goodyear Eagle!! Good deal), and lube the EVAP canister vent control valve. Oh and a new shift boot (the old one had essentially rotted away) and shift **** (beyond "smoothed by the hands of time"... more like worn down to the nub).
A little rust behind the right-rear wheel, and some rust spots are developing on the roof between the sunroof and windshield, but nothing too major yet...
I just did my safety inspection but she failed...needs new front brakes (no biggie) and a completely new exhaust (original is the definition of "rusting to pieces"). Gonna go get to work here soon.
Still runs like a champ though. Did 130 mph about a year ago only 3 miles after it hit 330,000. Hopefully many more miles to come!!
Old Jun 19, 2009 | 06:57 AM
  #279
$uperstarr124's Avatar
i have my 96 max which i paid 1300 for at 159,990
Old Jun 19, 2009 | 08:27 AM
  #280
borrowman's Avatar
98 SE 5 sp will turn 100,000 on my drive home today.
