Spring Wrap Method?
Old Sep 16, 2005 | 03:43 AM
goldmax's Avatar
Spring Wrap Method?
Anyone have the details on how to wrap noisy springs with the wire wrap from Radio Shack? I'm looking for the exact type of wrap you used and how you did it. I've got a nagging noise still coming from the front left front, and want to try to silence it. Everything up front is new, so I shouldn't be getting the noise at all.
Old Sep 16, 2005 | 04:10 AM
njmaxseltd's Avatar
Go to Nissan and get the OEM isolation sleves.
Old Sep 16, 2005 | 04:34 PM
ThurzNite's Avatar
Clear Vinyl Tubing (usually used for water like water fountains and refridgerators). I was told it doesn't freeze easily, nor will it harden with age (well, guess it depends on how many decades?). Get a caliper, measure the diameter of a coil, and get the appropriate size. I went with 5/8" inside diameter, and 7/8" outside. I have sprint springs. The rears required some creativity to install. The fronts were as easy as slipping it on (had to use a lil lube cuz 5/8" is exact diameter).
Jae
Old Sep 16, 2005 | 07:14 PM
RA030726's Avatar
I'm nutty for Nissans
when i had intrax, i just used wire loom.
Old Sep 17, 2005 | 02:57 AM
goldmax's Avatar
Sounds good. Thanks to both for the help and pics!
Old Sep 17, 2005 | 03:38 PM
RA030726's Avatar
i didnt use much at all
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
