Gasket Set Part Numbers??
Old Sep 16, 2005 | 08:15 PM
86maxima96's Avatar
I Broke OT
I plan on swaping out my IM and Valve Cover in the near future. I have decided to also replace the gaskets. Where is the best place to get the parts that I will need from and also, what are the parts that I will need? I have a discount code from Rock Auto to use and will purchase from there if they have what I need and if I can't find a lower price. Thanks.
Or if anyone has what I need for sale, PM me.
Thanks again.
Old Sep 16, 2005 | 09:20 PM
86maxima96's Avatar
I Broke OT
bump
Old Sep 17, 2005 | 06:17 AM
njmodi's Avatar
Do I get a tax break?
I bought the FEL-PRO kit from rockauto.com. I didn't like the tube seal construction compared to the OEM ones.. so I ended up ordering OEM parts instead. The only parts I used from the kit were the bolt grommets.
I would recommend OEM tube seals and the main gasket. Just order the bolt grommets from rockauto. I also used a OEM IM gasket - the OEMs ones are as cheap as the aftermarket ones, so no reason to stray from OEM in this case.
OEM parts for everything (tube seals, valve cover gasket and grommets) will run you 50 bucks or so per valve cover (From one of the discount dealers, Courtesy, Pinnacle, Midway, etc.).
mrc00l88
Jan 25, 2024 01:14 PM
AnsonJ
Jun 2, 2017 01:35 PM
espimax
Aug 25, 2015 01:16 PM
BassAddictJ
Aug 4, 2015 11:38 AM
