oil filter bypass valve - opens at high rpm
I read that above about 3500 rpm the oil filter bypass valve opens up and feeds unfiltered oil into your engine - is this true of the 9E000 filter as well? if so, why? is there a better filter that will still provide filtration and sufficient flow at high RPMs?
Where did you read this? The valve won't "open" at any particular RPM... it all depends on the pressure drop and how clogged the filter is. If you step on it, there is a good chance the valve might open up slightly... but you can't say with certainty that it happens at a particular RPM. Hope that helps.
I read about this at http://www.carbibles.com/engineoil_bible.html
there's also info about filter magnets and putting magnets at the bottom of your oil pan - have you ever tried this??
Originally Posted by sky jumper
great - now I'll be afraid to step on it.
Anyone know?
lowpost99
Oct 26, 2025 06:53 PM
sdotcarter
Sep 2, 2015 09:53 PM
Justin Kroll
Sep 2, 2015 11:06 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
