Check Engine Light Off But Can't Pass Inspection
Old 09-19-2005 | 01:23 PM
eLMo's Avatar
Ok I drove to my cousins shop and I turned off the check engine light off like a month ago. He checked the ECU with the ECU reader and the light was off but he still got a couple codes. There is a knock senor code and all the O2 sensors are out. Also there is a problem with the 3rd gear ratio in the transmission. I can't pass the inspection with that. I want ot know why the light wasn't on though with all these problems. Also he reset the codes and the knock sensor code comes back immediatly.
Old 09-19-2005 | 01:27 PM
njmodi's Avatar
Do I get a tax break?
Does the light actually work? With the key in the ON position, the CEL bulb should light up.. (with all the other cluster lights).
If it lights up then I dunno whats up with the codes being stored but the light being off.
If it doesn't light up when the key is "ON", then you need a new bulb.
If the 0304 comes back right away (with NO other codes), its time for a new KS. Check the resistance, the grounds and harness etc. first, but most likely the KS is bad.
In NY do they do an actual emissions test or just check for codes or both as part of the inspection?
GodFather's Avatar
Made in Taiwan
ghost codes...eventhough you manually set them off, the parts are still fouled, so they would always show up on a scan.
Old 09-19-2005 | 01:30 PM
njmodi's Avatar
No way o2 sensors will NOT set the CEL - the bulb might be blown.
Old 09-19-2005 | 02:08 PM
GodFather's Avatar
Made in Taiwan
yeah, on second thought, njmodi is right. i only have heard of KS ghosts, not O2...
Old 09-19-2005 | 03:52 PM
eLMo's Avatar
Well the light came back on while I was driving home. It decides to go on when it want's too. But when I turned the car on the light didn't even turn on. I know what you talking about how it turns on then off but nah, he was also saying that. Weird man. Maybe I did something wrong when I reset it. Does the screw on the ECU have to stay in a certain postition when your finished like to the right or to the left?
Also in NY they check the codes and do emissions. They just changed it. It used to be just emissions but no no more.
Old 09-19-2005 | 03:59 PM
njmodi's Avatar
The screw should be turned all the way anti-clockwise (i.e. to the left), once you are done retrieving codes.
Old 09-19-2005 | 04:00 PM
MDeezy's Avatar
I'd check the stickies on the position of the ecu screw. I believe its all the counter clockwise. My screw is jacked and pretty much keeps spinning in either direction.
killerVQ30DE's Avatar
Check screw to the left when finished.. but if its to the right I think your idle goes all whack
Old 09-19-2005 | 05:45 PM
eLMo's Avatar
Well that fixed one of my problems but the light went off drove a lil and came back on. I did not think that the screw would screw around with the idle. Thanks no more shaking and having to put in nuetural.
Old 09-19-2005 | 08:01 PM
filter27e's Avatar
When your KS is bad your engine sets itself to default "safe" timing tables. Should give you some inspiration to change it, basically you should get more power when you fix it.
Old 09-20-2005 | 04:48 AM
MaximaSE96's Avatar
Maxima Owner
NY just checks for codes atleast anywhere out of NYC.......they hook up to teh OBDII Diagnostic port and check for codes...but no actual sniffer
Old 09-20-2005 | 05:13 AM
nick's Avatar
Your monitors must be "set" in order to pass the OBD2 test, the light might be off , but if the monitors are not set - you'll fail the monitors test.
next time you hook up your car to scanner, have them check your monitors, to make sure they are set, it takes certain amount of driving under certain conditions to set those monitors
Nick.
Old 09-20-2005 | 05:41 AM
deezo's Avatar
Keep in mind that you can't just run to get inpected soon after resetting the ECU. It takes a couple hundred miles (to be safe) for the ECU to hit its "full ready" state.
Old 09-20-2005 | 01:31 PM
Crooper_Hedder's Avatar
A broken knock sensor won't throw a CEL code. You usually find out about it when another part of your car breaks. When I had my Nissan Truck (before my Maxima) I had an O2 sensor throw a code. After I put in a new sensor and reset the ECU I went straight to DEQ and passed it. Resetting it clears all codes.
Replacing the knock sensor is SO fun. One of the few things in life that makes me glad that I have small hands.....
CorollaULEV
30
08-09-2021 08:11 PM
Justinmc760
08-23-2015 03:10 AM
maxinout93
08-20-2015 02:17 AM
beboski
08-16-2015 05:23 PM
doobadoo
08-15-2015 06:43 PM
Quick Reply: Check Engine Light Off But Can't Pass Inspection
