trunk mechanism won't latch
Old Sep 21, 2005 | 08:36 AM
NookieMax's Avatar
So I didn't secure a keg very well during transportation and the jolts sustained by the back of the trunk messed up the latch.
This has happened before, and a simple readjustment of the two bolts holding the bottom part of the latch fixed the problem.
I alread spent a good 2 hours trying to fix this problem and have come to the conclusion that the latching mechanism just won't hold the trunk close.
I simulated the latching action with a small screw driver and found that the latch would close, but then would reopen with out much force.
I'm pretty sure everything is aligned correctly and the that the latch just reopens everytime I try to close the trunk.
So, Has anyone else experienced this, and what did you do to fix it. Where would be the best place to look for a replace latch.
I've had a hard time finding junked maximas around my town, so if anyone knows anyone I'd great appreicate them contacting me.
Thanks for your help guys
Old Sep 21, 2005 | 09:54 AM
MDeezy's Avatar
probably just need a new latch. Anyone who recently wrecked their max should have it available for sale (if not already sold).
Old Sep 21, 2005 | 05:32 PM
NookieMax's Avatar
anyone know anyone with a parts car?
Old Sep 21, 2005 | 05:37 PM
MDeezy's Avatar
check the classifieds I think there are 3 97+ maxs being parted out.
Old Sep 21, 2005 | 09:08 PM
96blackmaxSE's Avatar
boost me.....
mine wont latch or pop from the lever inside the car....it worked fine before i had my subs inthere...
Old Sep 22, 2005 | 05:06 AM
njmaxseltd's Avatar
Most likely the keg rolled into the rear body pannel and pushed it out slightly. Thats the most common "keg in the trunk" issue we see happen at the body shop. Adjusting the height with the bolts isn't going to make it latch again. Take off the trunk inner trim lining and look closely at the alignment of the trunk lid and the latch mechanism. Have a friend help you by getting into the trunk to see whats going on. A few tugs with a slide hammer should bring the rear body pannel back into position again, or a visit to your local body shop should get her fixed up quickly.
Old Sep 23, 2005 | 11:39 AM
NookieMax's Avatar
thank you el presidente! (nice car by the way, love em sterling mist SE-Ls)
now I've gotta find a friend that'll trust me enough to sit in my trunk for a while... well it doesnt' lock anyways, should be fun.
Old Sep 23, 2005 | 12:19 PM
njmodi's Avatar
Do I get a tax break?
Be careful -> you don't want to lock it and jam it such that it doesn't open again...
Old Sep 28, 2005 | 09:45 AM
tuner001's Avatar
is athat a common issue, my trunjk wont open from the latch inside the car but the key works fine.. i also have a sub back there could that have messed w/ it?
Old Sep 28, 2005 | 10:00 AM
DaEnigma's Avatar
Um if you can not unlatch from the lever in the car first check the security trunk release disable on the lower trunk latch... It is a small metal switch that moves up and down to enable and disable the interior release...
Old Sep 30, 2005 | 10:30 AM
NookieMax's Avatar
whats a slide hammer?
REDinLV
Aug 15, 2024 12:30 AM
tarun900
19
Dec 20, 2021 06:57 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
