ABS light
Old Sep 22, 2005 | 05:06 PM
TriniRicanPapi's Avatar
ABS light
my abs light came on. nissan checked it and told me it was my right abs sensor that caused my light to come on. i don't want nissan to do it because they are charging almost four hundred dollars. where can i find this part and instructions on how to install?
Old Sep 22, 2005 | 05:12 PM
2 Da Max's Avatar
well u have to buy this part brand new, because if you take it out of another hub, it will get damaged. i tried it 2x
buy it, drill out old one, install the new one, screw on the 10mm screw on the splash panel, screw, screw on the 10mm screw onto the strut, plug it into the lines, and abs shiet under the hood from where the old connecter connected into before , and u good to go
if you dont understand or need further help pm me
Old Sep 22, 2005 | 05:59 PM
njmodi's Avatar
Do I get a tax break?
to what has already been said. When you try to remove the old one, the bolt will definitely shear off. You'll have to drill it out. Then just replace it with the new sensor and harness. Once you have the new part in hand, the replacement will all make sense. Just be prepared for the one one to be a pain to get out of the hub.
Check pinnacle nissan, jerry rome nissan, midway nissan or courtesy nissan for the best prices on genuine nissan parts.
mvm062
Nov 30, 2020 09:00 AM
bbsitum
Sep 6, 2019 07:31 PM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
maximusrising
Sep 2, 2015 09:55 AM
