What can i do to gain HP
ok i want more power out of my 95 auto max and the only engine upgrade i have is the injen Cai. Im planning on buying the cattman y pipe since it gains a good amount of hp for the money....i dont want to get an exhaust due to the loud noise...nor do i want to get headers since it is said not to gain as much power as the y pipe and it is more expensive. does anyone have any suggestion on what i can do to get some hp......
y pipe/ecu/VI/turbo/charger are the best, everything else doesnt help much.. Your suspension is huge, you can lose alot of power from being stock. most people say the intake takes away power, there a dyno by zack some where where these stats. but the fastest maxima seem to have a pop charger which is stock mid pipe with a cone filter on the end but you need to to build something so your filter doesnt rub on the inside.
Originally Posted by 2 Da Max
dont know if this make sense or not,but ever since i lowerd my car, whenever i hit the gas hard it doesnt peel out like used to
so im guessing gain on traction?
A stiff suspension will help your 1/4 mile times by keeping as much weight to the front of the car as possible. The stock suspension, you'll see the car rear back on launch, but thats not a good thing. An aftermarket suspension will keep the weight on the front of the car, reducing wheelspin. But as THT, then you get into wheelhop, but there are ways to work around it. Get a VI for sure, ECU depending on which VI you get (00VI is not necessary but nice, MEVI is necessary to feel the gains).
u can't have more power, unless u put either a 3.5 engine or put turbo in it, the Maxima has been optimized by the engineers at Nissan. so putting something like an exhaust or a intake won't do jack. at most it'll give u a little bit of power, maybe like up to 5 maximum HP, thats with everything... but then theres always nitro... lol
Originally Posted by eckohb
if thats the case, why does the y pipe, 00VI, and aftermarket ECU give proven whp/wtq gains? Even tuning with an SAFC-II adds extra ponies
Originally Posted by Stephen Max
Optimized maybe, but not for highest absolute power. It has undergone some optimization for power against emissions standards, noise and driveability tradeoffs (as well as other parameters, no doubt).
He sure will!!!!!!!!!!!!!! All that trouble and it MIGHT have 10 more hp stock. And probably alot less stock torque.
Beastly!
Beastly!
Originally Posted by AGRECORDS
buy an sr20det and you will have a true beast.......
Originally Posted by TurTLe*
nismoGTR. didn't we talk about how to get more hp on one of the other threads u started like 2 days ago?
The results are the same tho. Y, ECU, 00VI the basics.
Other Thread: More Torque
GTR, seriously, you need to get a life. All of your questions were answered in the other thread. There was no reason to make another thread.
I am going to thread ***** because this thread is done anyway.
I never understood why people SR20 swap. I thought a 240 means 2.4 liters. Wouldn't an SR20 be 2 liters? Unless the SR20 can take turbo a lot better, I am confused.
There's a reason for people loving the sr20det motors. Im not huge about those motors, but if it werent for it being a better motor than the Ka24, im sure people would just turbo their Ka24s then.
zzznightmarezz
09-21-2015 06:32 PM
