car idles at 2200 somtimes
Old Sep 24, 2005 | 03:32 PM
maximaintheface's Avatar
Hey my car idle's at 2200 rpm somtimes unless i put it in nuteral and take it up to about 6000rpm then it dropes back down. somtimes even if i rev it taht high it still doesnt work. any idea's. its not the throttle cable ive alreayd checked and all my hoses are hooked up also . any idea's?
Old Sep 24, 2005 | 03:48 PM
njmaxseltd's Avatar
Clean the throttle body and idle air control valve.
Make sure the spring on the throttle is nice and tight.
Check for binding of the throttle plate.
Check the cold idle plunger, make sure it's retracting correctly when the engine is warm. Also make sure the cold idle linkage isn't binding up.
Old Sep 25, 2005 | 12:58 AM
Just cleaned the tb and iacv about 5 months ago. it just started happening with in the last 2 months. ill check the other stuff though. thanks
Old Sep 25, 2005 | 02:22 PM
I checked everything seems to be ok. Any other idea's? also i didnt mention before that sometimes if i turn it off then back on it fixes it. Im just kinda confused.
Old Sep 26, 2005 | 07:45 AM
Chris99SE's Avatar
I know when i cleaned my IACV it did the same thing, racing idle on startup, clean it again, when you did your TB maybe you did not get everything and there is still a chunk of carbon in there. My IACV actually threw a CEL. Hopefully you don't need to buy one, they are almost $200 from the dealer.
Old Sep 28, 2005 | 10:22 PM
im pretty sure its clean I mean i totaly had eveything off and cleaned it out and had it all off again when i took the uper manifold off and it was still really really clean.
Old Sep 29, 2005 | 02:48 PM
Fulltone74's Avatar
My car does this sometimes, although rarely.
I sometimes start up and have an idle of 2000+ rpms.
Most recently my car was fully warmed up. I shut it off 'cause I forgot something in the house. I come back two minutes later, start it up, and my idle is 2000 rpms. I shut it off, restart, and idle was normal again.
Sometimes if it is idling at 2000+ rpms, it will suddenly come back to normal after a few minutes.
Old Oct 1, 2005 | 05:26 PM
ya i cant figure it out really. i havent treid to much but i think its somthin in the iacv
Old Oct 1, 2005 | 05:35 PM
lanky2882's Avatar
what is the cold idle plunger? im having idling problems but in the reverse way the rpms will drop to 500 or so.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
doobadoo
Aug 15, 2015 06:43 PM
Maxboy23
Aug 11, 2015 11:59 AM
