Brakes Squeal
Old Sep 26, 2005 | 11:44 AM
euser985's Avatar
Brakes Squeal
my brakes on my '98 se are always squealing when i stop and it's getting pretty annoying. is there anything i can do for that?
Old Sep 26, 2005 | 11:46 AM
njmodi's Avatar
Do I get a tax break?
What's the brake history? When were the pads replaced? Rotors turned? What brand pads? What type of rotors?
At a minimum you will have to disassemble and put some anti-squeal goop on the backs of the pads and shims... depending on the pad quality/composition, if that doesn't fix it, you might need to do a complete brake job using different pads (OEM, or Raybestos Quietstops for example).
Old Sep 26, 2005 | 11:48 AM
euser985's Avatar
to be honest i don't know, i just bought the car. but i had a '96 maxima before this car and the brakes on this one are very very good.
Old Sep 26, 2005 | 11:49 AM
njmodi's Avatar
You may want to inpect the brakes... they might be worn and it might be the wear indicator that is squealing. If that is the case, it's time for new pads.
Old Sep 26, 2005 | 11:53 AM
euser985's Avatar
but if the pads were worn, would the brakes brake so good?
Old Sep 26, 2005 | 01:06 PM
Maxima lover
I would say, take the wheel off and turn the steering wheel. You will be able to see the caliper has a little open space that you can look through and look at the wear on the pads. Make sure to do this on both sides because one side might have a stuck pin that has caused one pad to ware down quicker then the others.
Old Sep 26, 2005 | 01:34 PM
Like njmodi said, it could be the squeak sensors telling you to change the pads very soon. You'll still have good brakes in the meantime though. I think the squeek sensors trigger too soon, so I always bend them back a little on my cars and have them squeek when I have only 5-10% pad left. No reason to waste perfectly good pads.
Brakes on the Maxima are extreeeeemly easy, don't pay some smhuck to do it for you.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
